I bought a Lonnies performance double pumper kit with the stand alone harness off here a few months back. The wiring is pretty self explanatory but i just want to double check. Is the power just hooked up to the "stud" at the fuse box and then just grounded on the shock tower? A pic or diagram would be helpful, thanks!
Lonnies Performance
05-08-2012, 07:50 PM
On a 4th gen F-body it hooks to the battery.
The wires are labeled "battery positive & negative".
Kit also comes with brass battery posts for this purpose.
If you have a rear mount battery, then use the alternator.
Also to anyone that needs help installing my products.... call me on the telephone.
I do not live on here, so if you want answers, call me.
Thanks for the response I will probably be giving you a ring in the next couple days as I don't want to screw this up!
