Vehicles Wanted - WTB: 98-02 F body V8 auto roller
blky2k2z
05-09-2012, 12:12 AM
Looking for what the title says 98-02 z28 ss ta or formula a4 clean title car prefer no motor or trans T tops and leather a plus looking for a pretty clean car please no molested hacked up cars will travel up to 500 miles from Okc Ok a2zcontractorsokc@gmail.com thanks in advance
Mustang Hat'r 2
05-09-2012, 02:12 PM
I have a green TA that will be rolling this weekend blew the tranny up and I getting ride of it. Any intrest? Body and interior are realy realy nice for 98
Jay
blky2k2z
05-10-2012, 12:06 AM
Jay
You can email a few pics and price to email listed above also what all is included with car and factory options ect
Mustang Hat'r 2
05-10-2012, 12:48 AM
Go in here and look around
http://s1204.photobucket.com/albums/bb406/bigjay187/
It will be on roller wheels depending on condition of them 2200-2400, I havent gotten them just yet. ECU and harness will be there 195 on body, 40k on 10 bolt. You will need the full engine trans drop out, the rad upper mount and lid and exhuast. The interior is nice, I'd get a new upper console lid though its beat up and wrong color. Normal ops for a ta leather power everything t tops. I have things you can add or swap if you want, 12 bolt rear suspension stuff I have an exhuast, passetter headers y and hooker cat but there rusty crusty but cat is decent.
LMK
Jay
anyone interested in my car i am not really interested in parting it out as everything i have purchased is all part a plan and it would take someone doing the same thing to sell off some of the other parts,or a car without a motor.see the attachment I may sell car if price is correct how much are you wanting to spend
1999 TRANS AM INTERIOR IS GRAY LEATHER, ALL STOCK ,AND IN GOOD CONDITION.. ALL WINDOWS ARE TINTED 10% REALLY DARK.EVERYTHING WORKED AT TIME OF DISASSEMBLY.HAS AFTERMARKET RIMS CHROME,I HAD NO INTENTION OF REUSING THEM WITH NEW BODY WORK.T-TOPS PERFECT.
16K WORTH OF BODYSHOP WORK ,AND PAINT COMPLETE COLOR CHANGE (HOUSE OF COLORS) TANGELO PEARL INTERIOR FLOOR PANELS PAINTED ALSO.
ALL ELECTRICAL PARTS THAT ARE UNDER THE BODY PANELS OR HIDDEN AND HARD TO GET TO HAVE BEEN REPLACED(SO NO PANELS WOULD HAVE TO BE REMOVED FOR REPAIRS IF EVER NEEDED)
HEADLIGHT DOOR MOTORS,WINDSHELD WASHER PUMP,ALL LIGHTS,HORNS,TOO MANY SMALL PARTS TO LIST.ALL UNDERSIDE PLASTIC,& FENDER WELLS COVERS ARE NEW,ALL LENSES,EVERY PART HAS BEEN PAINTED BEFORE BEING REINSTALLED. BODY WAS COMPLETELY DISAMBLED AND PAINTED PIECE BY PIECE. ENGINE HARNESS COMPLETELY REDONE,RELOOMED,ALL WEATHER STRIPPING REPLACED,NEW RAPTOR RAMAIR HOOD.ALL FRONT BUMPER SUPPORTS REMOVED AND REPLACED WITH BURKHART CHASSIS SUPPORT..UNDERSIDED COMPLETLY STRIPPED AND CLEANED AND REINSTALLED ALL PARTS.FUEL TANK REINSTALLED WITH 340 PUMP KIT RACETRONICS HARNESS KIT,NEW SPRINGS,FRONT AND REAR SHOCKS,MOUNTS,SPRINGS SUPPORTS ETC..EVERY STOCK SUPENSION PART HAS BEEN REPLACED WITH EVERY BMR PART MADE FOR THE CAR INSTALLED. NEW POWER COATED SPINDLES.FRONT SPITTLER
EVERY NUT AND BOLT PAINTED BEFORE BEING REPLACED,
DOOR HINGES REDONE,THERE ARE JUST SO MANY PARTS REPLACED IT CAN NOT BE LISTED EVERY BODY PART WAS REMOVED. NEW POWER RADIO ATTENNA
LISTING OF NEW PARTS EITHER STILL IN BOX OR INSTALLED DURING BODYSHOP ASSMEMBLY ( AFTERMARKET & GM )
6LITEREATER DESIGNS FRONT SPILTTER $450.00
SUNCOAST RAM AIR RAPTOR HOOD $760 PLUS SHIPPING $150.00
ALL NEW LENSES $150.00
HEADLIGHT DOOR MOTORS $600.00(GM),WATER BOTTLE MOTOR,HORNS,POWER RADIO ANTENA, ETC..ALONG WITH ANY ELECTRICAL PARTS UNDER THE BODY PANELS
WERE ALSO REPLACED WITH GM PARTS(TO PREVENT HAVING TO REMOVE ANY PANELS AT LATER DATE FOR REPAIRS) ABOUT $800.00
ALL NEW GM WEATHER STRIPPING $500.00
NEW BODY PARTS (GM)
NEW INNER FENDER WELLS (GM)
ALL UNDERSIDE PLASIC PARTS WERE REPLACED (GM)
DOOR HINGES REPLACED
WIRING HARNESS RELOOMED AND CHECKED FOR ANY ISSUES $300.00
6 LITEREATER DESIGNS BLANK GAUGE CLUSTER TO INSTALL AUTOMETER GAUGES IN PLACE OF STOCK CLUSTER $40
ALL BELOW INSTALLED
PROTHANE MOTOR AND TRANS MOUNTS. $200.00
NEW SPRINGS,MOUNTS,STRUT MOUNTS $350.00
NEW TOKICO HP SERIES PERFORMANCE FRT AND REAR SHOCKS $440.00
BMR K-MEMBER LS1 SET UP FOR FACTORY MOTOR MOUNTS $520.00
BMR ADJUSTABLE FRT UPPER AND LOWER CONTROL ARMS $440.00 & $350.00
BMR FRT AND REAR SWAY BAR KITS 35MM & 25MM HOLLOW $ 400.00
BMR REAR LOWER ADJUSTABLE CONTROL ARMS $280.00
BMR PANHARD ROD ADJUSTABLE $149.00
BMR PANHARD ROD RELOCATION KIT $ 210.00
BMR TORQUE ARM ADJUSTABLE BOLT ON $ 399.00
BMR 4L80 TRANSMISSION (CONVERSION) CROSS MEMBER /TORQUE ARM RELOCATION MOUNT $249.00 (INTENDED INSTALLING 4L80)
BMR DRIVESHAFT SAFETY LOOP & TUNNEL BRACE $110.00
BMR SUB FRAME CONNECTORS BOXED WELD ON $170.00
BURKHART FRT CHASSIS AND BUMPER SUPPORT $250.00
GM POWER COATED SPINDLES $300.00
NASTY PERFORMANCE BILLET FUEL RAILS & F-BODY FUEL LINE SYSTEM,ALL FITTING NEEDED TO CONNECT TO STOCK FUEL LINE $339.00
60LB INJECTORS MOTOTRON $ 385.00
RACETRONIX 340 PUMP AND HEAVY DUTY HARNESS WITH EXTRA GROUND CONNECTION $249.00
FAST 102MM INTAKE MAINFOLD PORT BY TONY MAMBO FROM AFR(WORTH 15 TO 25 RWHP OVER STOCK 102) $900.00,$250 PORTING,$200.PAINTING= $1350.00
FAST INTAKE PAINTED TO MATCH VALVE COVERS (LSX454)
102MM THOTTLE BODY $359.00
COOLANT CROSS OVER PIPE KIT (GM PARTS) $109.00
TCI 8 BOLT FLEX PLATE $220.00
LINGENFELTER CONVERTOR BOX 58X TO 24X $220.00
ARP BALANCER BOLT $30.00
NEW GM OIL DIP STICK & TUBE $30.00
NEW GM OIL PUMP PICK UP TUBE AND SCREEN $50.00
MSD 3 HP LS1-LS7 STARTER $ 239.00
KOOKS 1 7/8 LONG TUBE HEADERS WITH LS7 FLANGES $1250.00
KOOKS COMPLETE DUAL EXHAUST WITH X PIPE POLISHED MUFFLES AND QUAD TIPS,(THIS KIT WAS THE VERY FIRST PRODUCTION UNIT SHIPPED)
UNIT IS MARKED AS THE FIRST KIT,GOOD TO 1200 HP DUAL 3 INCH ALL THE WAY BACK. (THE FINEST KIT ON THE MARKET) $1900.00
LSX 454 GM CRATE MOTOR 620HP,590 TQ BRAND NEW AS FROM GM.STILL SEALED $10,400. WITH TAX
ALL ENGINE BRACKETS HAVE BEEN POWER COATED $250.00
NEW GM F-BODY OIL PAN PAINTED TO MATCH LSX BLOCK $ 220.00,PAINT $100.00
LATE MODEL GM 4L80 TRANSMISSION
ELDEBROCK LS1 WATER PUMP HIGH FLOW
HIGH FLOW THERMOSTAT AND HOUSING
ABOUT 44,000.plus INVESTED, OR AT LEAST THAT IS WHAT IS LISTED ABOVE,THERE ARE SOME PARTS I HAVE FORGOTTEN TO LIST
THE CAR IS STILL AT THE BODYSHOP STILL HAS A FEW SMALL DETAILS TO COMPLETE NEEDS ITS FINAL WET SAND AND BUFF THE BILL IS PAID ALL 16K PLUS NOW
THIS CAR WAS BUILT TO BE A SHOW CAR THE UNDERSIDE IS PAINTED AND SPOTLESS IT WAS ALSO MEANT TO RUN 9'S ON SPRAY SHOULD BE ABLE TO RUN 10'S OFF THE BOTTLE WITH THE A/C ON (LOL). I WAS CRIRPPLED IN A MOTOR CYCLE CRASH AND JUST HAD SURGERY THAT WENT WRONG WE BELIEVE I WONT BE ABLE TO DRIVE AS I AM FROM THE CHEST DOWN UNABLE TO MOVE AND HAD TO HAVE MY NECK FUSED DUE MY SPINAL CORD SPLITING IN TWO LAST MONTH
NEW BODY PARTS (GM)
ALL BELOW INSTALLED
