Sponsored by: DashLynx
NEED HELP Figuring Out Which LED I Need...
Old 05-09-2012, 03:12 AM
DoggyB22's Avatar
Default NEED HELP Figuring Out Which LED I Need...
So I'm going to get these from superbrightleds.com for my Camaro
5 cool white WLED-xHP6-AC: LED T10 Wedge Base Bulb for the main cluster
2 red WLED-xHP6-AC: LED T10 Wedge Base Bulb for the turn signals
1 warm white WLED-xHP6-AC: LED T10 Wedge Base Bulb for the high beam light
2 cool white 74-xHP for the door light by the door lock
1 cool white RL4410-CWHP9 for the rear dome light
2 cool white 3157-x45-T for the reverse lights
Now which LED do I get for the steering wheel, rear view mirror, the whole dash, & rear license plate??
Old 05-09-2012, 09:00 PM
DoggyB22's Avatar
Old 05-21-2012, 01:46 AM
DoggyB22's Avatar
BUMP! Found out a couple more.....
Old 05-23-2012, 12:55 AM
DoggyB22's Avatar
http://www.youtube.com/watch?v=NP0mQeLWCCo
Old 05-23-2012, 01:57 AM
HotWhipT/A's Avatar
https://ls1tech.com/forums/appearanc...-led-list.html
You'll need to solder in your own LEDs and resistors for the steering wheel, ASR and fog light switch. You'd need to solder in LEDs for the odometer to if you want to change the color, but no resistors are needed for that one. All of which I can do for you if you'd like. I've had people send me their stuff a few times.
Quick Reply: NEED HELP Figuring Out Which LED I Need...
