P0306 Cylinder 6 Misfire!
Old 05-09-2012, 08:28 AM
BIGDATOWN's Avatar
Default P0306 Cylinder 6 Misfire!
I have this misfire problem ONLY on cyl #6 And ONLY at idle. Any and all ideas would be very helpful in things to try.
Car is a 2001 Camaro z28 A4 with 170k miles
Old 05-09-2012, 08:45 AM
godlyxdan's Avatar
need more info.
Any Mods done?
Has it recently been sitting for a while?
Take a Known good plug and coil from a different cylinder and plug it into #6, if the miss moves with the coil then you know what the problem is
Old 05-09-2012, 08:46 AM
1ltcap's Avatar
Originally Posted by godlyxdan
need more info.
Any Mods done?
what he said. also, check ALL basics.
Old 05-09-2012, 10:24 AM
BIGDATOWN's Avatar
It has been doing it since I bought it and then it was bone stock! It now has lid, filter, bo white tb, longtubes, ory, and a converter.
I tried the moving of the coil, wire and plug. No dice. But like I said, it only does this at idle and as far as I know the car didnt do alot of sitting.
Old 05-09-2012, 11:23 AM
1ltcap's Avatar
why would you purchase a car with a misfire, and then modify it before finding out what the cause of the misfire is?
get an infrared thermometer, and check the exhaust temp of that cylinder. that'll give you some clue.
use a long screwdriver, and place the tip of it on that injector, then put your ear on the handle, and listen for a good solid clicking noise. compare that to the sound of one on a good cylinder.
hook a vacuum gauge to manifold vacuum, and watch it. is it steady? bouncing?
Old 05-09-2012, 11:46 AM
crainholio's Avatar
Like 1ltcap said, the injector is your next diagnostic step...I'd swap it with another cylinder and see if the problem follows it.
Old 05-09-2012, 11:51 AM
SVTconfused's Avatar
if swapping the injector doesnt fix it... im leaning towards a bent valve/ bad seat...
my 2000 z28 had this exact problem on #6
Old 05-10-2012, 09:10 AM
BIGDATOWN's Avatar
My next step will be swapping the injector with another cylinder and seeing if the misfire moves. I will update with the results.
Old 05-15-2012, 10:03 PM
BIGDATOWN's Avatar
Moving injector didnt change anything. I am going to run a compression test and if it comes back ok I will pull the valve cover next.
Old 05-15-2012, 10:28 PM
jgb989989's Avatar
I have the same problem on my car. I changed plugs, wires, coil, injectors. even pulled the valve cover after running a compression test. All checked out good. I found a bunch of oil in number 2 coil were it plugs into the harness. Maybe its just me but it feels like it when away after I cleaned the coil and moved it to another location.
Old 05-16-2012, 08:09 AM
1ltcap's Avatar
do you have a noid light? if not, go to pepboys, and you can buy one for a couple bucks.
disconnect the injector, and put the noid light in the harness, then start the car. it should be flashing. if it's not, that injector driver's not firing the injector for some reason.
Old 05-16-2012, 08:28 AM
99YENKO's Avatar
Post a pic of the plug..
Old 05-20-2012, 05:46 PM
BIGDATOWN's Avatar
Cyl#2 235 PSI
Cyl#4 224 PSI
Cyl#6 140 PSI
Plugs looked perfect. MAYBE a lil lean
Old 05-21-2012, 05:35 AM
crainholio's Avatar
#6 has a problem.
If you want to diagnose further and have a compressor, you can use a leakdown tester to determine whether the leak is at the valve(s) or the rings.
Otherwise it's time to pull the cylinder head.
Old 05-21-2012, 07:56 AM
BIGDATOWN's Avatar
Basically just knowing if its valves or rings is where I want to be right now. We plan to pressurize the cylinder and see if we can tell where the air is going. My vote right now is a broken ring. We are going to pull the valve cover tonight also and make sure the valvetrain is all ok.
Old 05-21-2012, 10:25 PM
BIGDATOWN's Avatar
Alright, We pressurized the cylinder and leak is at the exhaust valve. It is 1 of 3 things, carbon build up, bent valve or burnt valve. Seafoam is next! I will post back later with more results.
Old 05-22-2012, 08:41 AM
1ltcap's Avatar
when you pressurized the cylinder, did you make sure both valves were closed? by either loosening the rockers, or making sure that both lifters were ont he base circle of the cam?
Old 05-22-2012, 08:55 AM
BIGDATOWN's Avatar
We made sure we were on the base circle.
Old 05-22-2012, 09:00 AM
1ltcap's Avatar
Cyl#2 235 PSI
Cyl#4 224 PSI
Cyl#6 140 PSI
i don't know how i missed this post. unless there's something very different about these engines, 224, and 235 are too high.
cranking compression on everything i've ever worked on should be between 140 and 175. running compression is generally about half of cranking compression.
Old 05-22-2012, 09:12 AM
BIGDATOWN's Avatar
Yes the number sounds high, but it could also be the cam degree that makes the cranking compression higher. This compression number is perfectly fine for these motors.
Quick Reply: P0306 Cylinder 6 Misfire!
