Anyone have Cam only MS3 dyno numbers?
Old 05-09-2012, 10:21 AM
JakeyLS1's Avatar
Default Anyone have Cam only MS3 dyno numbers?
Im gonna do an ms3 eventually and Im just interested in the output numbers
Old 05-09-2012, 10:46 AM
MikeWS6's Avatar
It really depends on the rest of your setup and how well it is tuned. With a good tune it should get in the 390-410 hp range assuming you have full bolt ons.
Old 05-09-2012, 10:57 AM
JakeyLS1's Avatar
Those number with a cam only and full bolt ons? Thats pretty good. What about with heads as well?
Old 05-10-2012, 11:45 PM
desertLS1's Avatar
no ones ever installed this cam. install it and let us know what it makes.
Old 05-10-2012, 11:49 PM
dreww's Avatar
That cam on my car with stock 241s and vararam, ls6 intake, long tubes, hi flow cats, cat back put me at 396hp/375tq
Old 05-11-2012, 05:31 AM
krissoto's Avatar
Chk out the dyno section, and search ms3. There are quite a few guys running them. Camscam02 has done some amazing thing with his, search some of his threads. I've got 2 buddies that have done them, both over 400 hp. And one went a 6.8x on the motor 1/8 mi.
Old 05-11-2012, 11:50 AM
MikeWS6's Avatar
It depends on what heads. It could be anywhere from 430 - 470 depending on what type of dyno.
Old 05-11-2012, 12:01 PM
NVUSZ28's Avatar
Cam Only, Bolt Ons, A4: 400 M6 425 rwhp.
Old 05-11-2012, 01:21 PM
badazz81z28's Avatar
You need to consider not everyone Dynos their car. BTW dyno numbers are subjective as there are too many variables anyways. I have seen combos on this site that do 440 RWHP and the same combo do 410 RWHP from someone else (People inflate ie LIE about true numbers)
Call TSP, they will tell you what to expect. I can say a good cam that is choked out by a bad intake and the low flow exhaust will hurt you.
Old 05-11-2012, 10:02 PM
marvinseah's Avatar
2004 Z06 with MS3 and full bolt-ons. 440/399 "honest" Dynojet SAE
Old 05-12-2012, 04:30 AM
PREDATOR-Z's Avatar
This is INTERNAL section. For DYNO numbers go to dyno section.
Old 05-12-2012, 07:04 AM
kidcamaro98's Avatar
412rwhp with just a full exhaust.
600.8rwhp 638rwtq on a 150 shot.
Old 05-12-2012, 07:15 AM
CustomX's Avatar
Good numbers, my cam only tqrv3 made 411rwhp and I'm putting a hsw wet kit on it this weekend. I'd be pumped if I made close to 600 lol. You upgrade the pump?
Old 05-12-2012, 10:59 PM
Mazzenger's Avatar
With a good free flowing exhaust, fast intake and gearing the MS3 will make your car fly.
No worries
Old 05-13-2012, 07:56 AM
yeah 42lb injectors and a racetronix fuel pump and hot wire kit.
Old 05-13-2012, 08:00 PM
94green1le's Avatar
my t/a made 420 rwhp and 390 rwtq with the MS3, ful exhaust, and ls6 intake
Old 05-17-2012, 12:30 AM
simplysix's Avatar
what did you do the the bottom end to handle that?
all stock? rod bolts?
Old 05-17-2012, 07:10 AM
stock. Ported ls6 oil pump and thats all.
The car actually kept blowing the tires off on the dyno
http://www.youtube.com/watch?v=b8E9Y...4&feature=plcp
Old 05-17-2012, 08:15 AM
simplysix's Avatar
[QUOTE=kidcamaro98;16321820]stock. Ported ls6 oil pump and thats all.
The car actually kept blowing the tires off on the dynoQUOTE]
very impressive numbers and nice vid man. How do you like the cam besides the actual numbers (how streetable, rpm range, gas mileage, etc). What gears are you running?
Old 05-17-2012, 09:01 PM
im running 4.11's in a moser 12 bolt on a 28" nitto 555r.
I love it. It does surge around 1500rpms but I deal with it.
Quick Reply: Anyone have Cam only MS3 dyno numbers?
