Dyno Guesses & Bench Racing Forum - 5.3 h/c/i/e
milktasd
05-09-2012, 12:41 PM
Building a 5.3 for my 00 Sonoma and finally got all the pieces for my motor in.
5.3 with new rings and bearings
Ported, polished, valve job, bowl job, milled 30 243s
Ls6 intake
85mm maf
Ls1 tb
Ls6 injectors
Spectre cold air intake
Brp longtube headers 1 3/4"
Eps 218/226 .595 .598 112+3
All going through a t56 and a 4.10 gear 7.5" rear on stock wheels and tires. Hope to have the motor in next month and be able to drive it by July. Will be going to eps for a dyno tune. Just curious what everybody thinks it will make.
Gunslinger09
05-09-2012, 09:20 PM
Ls6 intake
85mm maf
Ls1 tb
Ls6 injectors
I think you will hit 395HP.
milktasd
05-10-2012, 05:25 AM
Hope so. That is what my friend and I think it will make too or around there. Would love to see 400, but won't complain if it's less.
carguy_24
05-10-2012, 08:48 PM
I'll be watching this thread because I am considering going the 5.3L route later.
milktasd
08-16-2012, 11:32 AM
Just an update with more parts:
Added a ported throttlebody and depending on room for exhaust 3" duals with x pipe or 3" y pipe with magnaflow catback. Will also have cutouts. Hoping to be on the dyno by the end of the month.
milktasd
09-28-2012, 06:57 AM
Headed to eps tomorrow for dyno and tuning.
The exhaust is 3" mandrel bent through dual in single out magnaflow muffler and also added an under drive crank pulley. Truck feels strong. Pulls hard to 6500, might end up raising the rev limiter because it doesn't stop pulling. I'm happy with the butt dyno can't wait to see what the actual numbers are. Here is the idle clip http://youtu.be/bym4z5bO_uw
milktasd
09-28-2012, 09:39 AM
2000 Sonoma 5.3/t56
Ported, polished, milled 243s
Ls6 intake and injectors
Ported tb
85mm maf
Cold air kit
Under drive pulley
160 thermostat
3" mandrel bent exhaust dual in single magnaflow with dual cutouts
4.10s stock rear with stock size tires
carguy_24
10-02-2012, 07:55 PM
Still watching this thread and your truck sounds nice. I'll be keeping an eye out to see your dyno numbers after you get the tune.
milktasd
10-02-2012, 08:31 PM
Made 340 rwhp with the cutout closed and 370 rwhp with the cutouts open.
Cutouts closed
http://youtu.be/1ZMswV8lMQo
Cutouts open
http://youtu.be/zDidm-N233Y
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
