High pitched whine, like a bearing noise
Old 05-09-2012, 06:14 PM
ls1fst98's Avatar
Default High pitched whine, like a bearing noise
Car has rungreat, took it for a drive and about 5-7 miles in it starts making a high pitched whine. Thought it was a belt idler pulley, so I tried to lube them and have changed them, no dice. It's not in the drive train as it does it standing still but not at idle, just above idle at about 1500-2000 and goes away under acceleration and returns when cruising. Ac belt is off the car, so I'm thinking either water pump or alternator. The ps fluid is full, no leaks. Any help would be greatly appreciated. If the rain will stop I'll start the car without the belt on and see if it's still there.
Old 05-09-2012, 08:03 PM
US_Army_Z28's Avatar
Im puttin my money on alternator
Old 05-09-2012, 08:19 PM
ls1fst98's Avatar
That seams to be the culprit. I've never heard one make this noise. It's horrible. I spin it by hand and u can feel and hear where it's hanging.
Old 05-09-2012, 08:24 PM
Yeah that was the first thing that came to mind when i read your post. I hhad a 95 z28that did something similar to this to me. Mine gave me a warning before the squeel though that i didnt pay attention to. I noticed when i accerlerated my voltage meter went up to normal levels but at idle it would drop down to barely above red. Sure enough a few weeks after this started i got the squeel that souns alot like whhat youre describiing
Old 05-09-2012, 08:57 PM
ls1fst98's Avatar
yeah mine used to just die and have no output, this one is still putting out 13.8-14.4 at idle and at speed. it did sit a while so idk. oh well, my back up alternator (yes i have a backup) is at the shop getting a once over and will be in the car tomorrow.
Old 05-09-2012, 08:59 PM
Welel hopeefully thatll knock out the problem
Old 05-09-2012, 11:08 PM
gMAG's Avatar
A papertowel tube, to your ear, will give you a good idea where the noise is from.
Do this away from your neighbor's view.
Old 05-11-2012, 06:43 AM
ls1fst98's Avatar
moving this topic to the internal, noise is something inside the motor.
Old 05-11-2012, 08:15 AM
Ballzee's Avatar
are you sure somebody didnt slap a procharger on and you didnt notice..
Old 10-31-2016, 01:14 AM
drew white's Avatar
Sorry to bring up this old thread, but did you ever find out what it was? My ls1 is making a whine but it's not coming from the accessory drive or transmission. Thanks
Quick Reply: High pitched whine, like a bearing noise
