Carbureted LSX forum - Msd 6ls question
View Full Version : Msd 6ls question
boosteds10
05-09-2012, 07:01 PM
Will the msd 6ls box pull timing when referenced to boost from the map sensor?
Pop N Wood
05-09-2012, 07:44 PM
The manual says it is capable of providing advance or retard for either vacuum or boost. It can be set to use up to a 3 bar MAP sensor and allows you to modify the curve at boost pressures.
So while I have never done it from reading the manual I would say yes.
boosteds10
05-09-2012, 07:57 PM
Thank you! That's what I needed to know.
ZONES89RS
05-09-2012, 10:54 PM
Thought i told you before. BTW, turbo i got from you is on a guys TA making 560 RWHP and 640 TQ at 10 pounds, that is on a stock 6.0 with a blower cam.
boosteds10
05-09-2012, 11:11 PM
You sure you got the right person?
ZONES89RS
05-10-2012, 08:01 AM
Well, think I confused you with Daniel, a local friend that did a ls1 swap in his s10, his DN here is Boosted s10, sorry.
