80lb injector data base tune
i was wondering if anyone has injector data for the ever popular siemens deka 80lb injectors. i bought some and have them installed and ready to start logging and tuning my turbo setup except i have no data for these injectors to even start a base tune. I ve searched and raided the hptuners repository but cant find anything. If someone can point me in the right direction it would be greatly apprecitated
Bump. Need the same thing.
JakeFusion, are you running that injector data currently? Reason I ask is I've got a turbo 5.3 silverado with a walbro 450, deka 80's and factory return style rails and vac/boost ref fpr
I'm having issues getting it to run right. It ran 'great' for 6 months or so until recently when it got cold. When looking into this is when I discovered several things in the tune that were wrong, one of those being injector data.
Thanks for any advice!
What is the part number for the injectors you are running?
Did you carry the 0kpa line across the entire table for IFR and offset? You need to do that for a referenced regulator. Did you scale the tune?
Same question for you.
I haven't tried JakeFusion's data yet, I've saved another tune and started copying over the data from his tune, so far i've changed the following:
1.) IFR flatlined at 92.69lbs (pressure @58psi)
2.) Copied first column of voltage offset table across all columns
3.) Copied min inj pw
4.) Short pulse adder and short pulse values
5.) Copied min transient fuel milligrams
The part number for my injectors is: FI114991
The one thing that makes me wonder about the data, is Initially I was trying to come up with my own data, so I started searching around and found this link: http://siemensdeka.com/specsheets/FI114991.pdf.
This spec sheet contains a 'voltage offset' line graph towards the bottom, which doesn't visually line up with the values showed in JakeFusions offset vs voltage table (at least from what ive noticed). Thoughts?
Thanks again for any input !
