Cleaning tap size for head bolts?
Old 05-10-2012, 10:07 AM
FLYNAVY30's Avatar
Default Cleaning tap size for head bolts?
I know the M11 bolts are a 2.0 thread pitch, anybody know what the M8 bolts on the heads are? Im trying to buy the proper ARP cleaning taps for the head swap. Thanks
Old 05-10-2012, 10:47 AM
badazz81z28's Avatar
M8 X 1.25
I have one, I just used once. $30 shipped.
Old 05-10-2012, 12:00 PM
FLYNAVY30's Avatar
cool, do you have the M11x2 as well? If so Ill buy them both from you
Old 05-10-2012, 12:18 PM
I actually just sold the 11mm.
Old 05-10-2012, 03:08 PM
93LS1S10's Avatar
i just used a 8x1.25 from the local hardware store. i did buy the long one though.
Old 05-10-2012, 05:44 PM
You didnt use a "Tap" did you???
ARP chasers just "clean" the threads....TAPS cut and weaken the threads.
My paypal is badazz81z28@yahoo.com
Old 05-10-2012, 06:29 PM
FLYNAVY30's Avatar
cool....Ill send you the 30 bucks when I get home in an hour...much appreciated!
Old 05-10-2012, 07:50 PM
FLYNAVY30's Avatar
money sent, shipping address should be on the Pay Pal receipt, let me know if its not.
Thanks
Old 05-10-2012, 09:51 PM
93LS1S10's Avatar
Yes but it went in will hardley any effort. No material was removed just crud.
Old 05-11-2012, 01:48 AM
Predator's Avatar
So what's the problem with taking a used head bolt, grinding a groove in the threads, and using that to clean out the threads? Just wondering.
Old 05-11-2012, 08:35 AM
Because its not very effective. You should see all the loctite the chaser got out that the cut bolt didnt. Trust me, I'm cheap and don't like to spend the extra cash. I ended up buying both chasers.
Old 05-11-2012, 02:30 PM
Predator's Avatar
Thumbs up
Heck, if you're getting more crud out with the chaser my hat's off to you. I used a combination of rags, cut bolt, and high pressure air. It worked out okay. I'd be afraid of altering the threads with a chaser, but I could be completely off base. Anyway, good luck with your install!
Old 05-12-2012, 02:08 AM
RonSSNova's Avatar
I used an old head bolt ground flat on 2 sides.
After cleaning with that, and making sure all the coolant was out, my ARP studs screwed in all the way down by hand.
Ron
Old 05-12-2012, 05:47 AM
therabidweasel's Avatar
^+1 (with lube)
Old 05-12-2012, 08:26 AM
Ron
To each their own I guess. My studs absoulty have zero resistant going in after being chased. Before they would go in, but get hung up on the way down. Bottom line is the bolts will go in, but torque accuracy may or may not be effected by crud in the holes.
This is just like the "degree the cam" thread. People don't do that either and get by. Some people are just not too concerned about the little details.
Old 05-12-2012, 04:39 PM
Predator's Avatar
Just want to add that I was concerned about the details of making sure that my bolt holes were clean, in fact I spent a whole day on that and cleaning off the old gaskets, it's just that the method I used with the ground-out bolt and air worked great. Anyway, sounds like you're in good shape with the chaser.
Old 05-12-2012, 05:19 PM
Evans752's Avatar
This is GOOD INFO to know considering that I am in the middle of a head swap / change.
Quick Reply: Cleaning tap size for head bolts?
