Special Edition Vehicles - Will the real WS6 please stand up
View Full Version : Will the real WS6 please stand up
Emily Callman
05-10-2012, 12:23 PM
I'm currently looking for and at 2000 T/A convertibles. I've found a exceptionally clean dark blue 2000 with 80K miles. Owner is representing that it's a wS6. It has the sticker on the back and WS6 wheels but after reading these forums looks like could add those from aftermarket sources. Is there a sure fire way to confirm it's a factory WS6?
Thanks experts!!!!
rad23
05-10-2012, 12:24 PM
vin number,
rad23
05-10-2012, 12:25 PM
you really can make any of these cars look like whatever you want
YellowTA1
05-10-2012, 01:02 PM
vin #, and also the codes on the inside of the door jam, if it's a true ws6, it will have ws6 as one of the codes.
babbage1109
05-10-2012, 01:07 PM
It won't show up in the vin unless you actually look up the whole thing but the rpo build code on the door will tell.
Jake18
05-10-2012, 01:10 PM
theres a code on the door jam that says WS6 if its real
Z28/2002
05-10-2012, 04:02 PM
The only way to tell if it is a true WS6 is by looking at the RPO codes. You can take the VIN to a dealership and have them run it and they'll print off the RPOs also
US_Army_Z28
05-10-2012, 07:54 PM
Rpo codes ws6 and ws9 must bothe be there. Ws9 is the code for the ls1 and the ws6y makes it a true ws6
Emily Callman
05-10-2012, 09:54 PM
Thanks! Checked the codes and ws6 is there
US_Army_Z28
05-10-2012, 09:56 PM
Now just makee sure the vin on the rpo code sticker matches the vin plate on the car. So easy to change a sticker or a door
Emily Callman
05-10-2012, 10:00 PM
Found it. Both are there. Thanks!
Z28/2002
05-11-2012, 11:00 AM
WS9 is for the Formula conversion, all V8 cars will have the "LS1" RPO code
All three of these codes need to be on the sticker for a true WS6 Trans Am
WS9, Y82 and WS6
US_Army_Z28
05-11-2012, 11:14 AM
Like i said the ws9 is the ls1 code for pontaic
JohnnyBs98WS6Rag
05-15-2012, 11:11 AM
WS9, Y82 and WS6
TA Verts will have Y84 instead of Y82. Unless its one of those rare Formula Vert WS6s, it'll have W66 instead of Y82 or Y84.
Z28/2002
05-15-2012, 04:35 PM
I'm used to talking about the T-Top cars, lol
Thanks for adding the info
