Nitrous Oxide - Using a 100 NX wet kit and M6 trans in what gear should I spray?
BIG RAM 1
03-01-2002, 02:42 PM
I need to know what gear it is safe to spray in with a 100 NX wet kit and a M6 trans...I'VE never sprayed before..trying to be safe?
Thanks
BIG RAM 1 = RED 2001 WS6 M6
>HPP III, K&N, Hotchkis shock tower brace, Mac headers & offroad Y-pipe & 10 bolt girdle cover, O2 simulators, Raven muffler, Ls1 Air Lid, MSD wires, NGK plugs
LS1 Kyle
03-01-2002, 02:54 PM
Don't even try first gear on the steet. You can safely spray in second after 3000 RPM. Actually it's safe to spray in first too, but I wouldn't recommend it unless you were on sticky tires and that might not be good for your rear end either.
To be safe, only spray between 3000-6000 RPM and don't spray deep into 5th or any of 6th at all!
Have fun...
[ March 01, 2002: Message edited by: LS1 Kyle ]</p>
BIG RAM 1
03-01-2002, 03:28 PM
Thank LS1 KYLE
Slowhawk
03-01-2002, 04:11 PM
I spray 1st-4th with a window switch set at 3000-5800.Just be carefull in first since you'll light them up and not hit the rev limiter.
ANIL8U
03-01-2002, 04:27 PM
I would defiantly get a window switch! If you ever miss a gear or hit the rev limiter, you can damage your intake or air box! In addition, if you have an SS you will lose the grill that is in the scoop! (I have hit the rev limiter once and all this shit broke)
i have my window switch set at 3000-6000, and i can spray in 1st gear, but i dont try to launch my car hard at all. i dump it at like 2000 and then it pulls till it hits 3000, then its like a rocket ship. but that is on drag radials, on gsc's, 2nd gear about spun the car around.
12 bolt and clutch on the way!!!!!!!!!!!!!!!
69Muscle
03-05-2002, 09:46 AM
1st gear BFG's with a 3000rpm Window switch. Hang on!
2000 Camaro SS
03-09-2002, 12:08 AM
1st, 2nd, 3rd, 4th gear window switch did 3000 but changed to 3300 up to 5800 on Nitto drags. Have a WOT MSD RPM switch, fuel safty cut off also. With new mods listed below this summer out of the whole. <img src="gr_grin.gif" border="0">
[quote]Originally posted by 69Muscle:
<strong>1st gear BFG's with a 3000rpm Window switch. Hang on!</strong><hr></blockquote>
it wont 60 foot, but it made 120.7 mph friday night on a 100 shot. its not even pulling hard till the 330 foot mark. but man what a rush!!!!
nitrousc5
03-11-2002, 07:31 AM
if you can hook, then in any gear >3k rpm, to include 5th and 6th (especially if you make an assult on top speed run)
top speed.....!!!! scarey!
<img src="gr_eek2.gif" border="0">
