OBD2 not working
Old 05-10-2012, 09:42 PM
SurWagon's Avatar
Default OBD2 not working
RED/BLUE pcm lq4 into a Grand Wagoneer.
Blue pin 58 to OBD2 pin 2 showing ~0.4v fluctuating
OBD2 4 & 5 grounded
OBD2 16 is hot at all times (run through silverado fusebox)
Engine starts up and appears to run fine. However, when I hook my ELM 327 up it says failure to detect protocol. I'm confused why it doesn't work.
Any ideas?
-Nick
Old 05-11-2012, 09:25 AM
bczee's Avatar
Nick
Is that ELM 327 a Bluetooth device ?... I heard that some of the eBay ones may or may not work all of the time.
Might try a cabled Scanner to verify if you are getting Serial data or not.
BC
Old 05-11-2012, 06:01 PM
SurWagon's Avatar
It's a serial cable with a USB adapter. I've used it on a subie and a ford ranger with no problems
Old 05-11-2012, 07:48 PM
SurWagon's Avatar
I've also wired up an 02 silverado dash and that does not seem to function either. The idle is high (i'm guessing around 2k).
The pcm was tuned by wait4meperformance. I told them to remove VATS. Could that have caused the serial data issues? I saw in another thread that the serial data voltage should varry between 0-7v. I'm getting 0.05-0.4ish.
Old 05-11-2012, 09:39 PM
LS1MCSS's Avatar
Here is a copy/paste from from another page I found. It looks like 0-7 volts is correct,
"The class 2 data was
at a resting level of 0 volts and was pulled high to around 7 volts to talk."
Old 05-13-2012, 12:19 AM
SurWagon's Avatar
Ran a new wire from pin 58...nada
Tried pin 59...nada
cleaned connectors ....nada
Still getting 0.2-0.4v.
Any ideas, has this happened to anyone else?
Old 05-13-2012, 07:04 AM
LS1MCSS's Avatar
Can you get a different scanner from someone and try it? I think the problem is with your scanner.
Old 05-13-2012, 03:33 PM
SurWagon's Avatar
Went to AutoZone and got the cheapest scanner and it was able to read the computer. No error codes.
I guess my scanner doesn't like the pcm.
Thinking of ordering a PLX Kiwi bluetooth for the droid. My dad has one and likes it. However, I would like hptuners so I can play with things.
Old 05-14-2012, 12:52 PM
SurWagon's Avatar
So, I have to use pin 59 for the OBD2 port to work. Tried putting it back in 58 and running 59 to the dash cluster....fail.
Just a heads up to future swappers
Old 05-14-2012, 04:19 PM
aknovaman's Avatar
Bluetooth, just eBay elm327. Cheap and functional.
Old 05-14-2012, 06:46 PM
bczee's Avatar
I had picked up one of them ebay elm327 last month, using it with my Xoom and installed Torque... works pretty good. Still learning about is other Advanced functions. Fun to play with and monitoring while I driving down the road.
BC
Quick Reply: OBD2 not working
