What if you had a cheap iron headed 6.0
Old 05-11-2012, 11:27 AM
kainedogg's Avatar
Cool What if you had a cheap iron headed 6.0
Lets say the fates smiled on you and you were blessed with the older iron headed LQ4. Out back sat your hypothetical '84 C10 in need of EFI\LSx goodness. What combination of stock parts would bring this motor to life? ie, stock block but L92 heads or block and 799 heads with 5308 cam.
Old 05-11-2012, 05:38 PM
kainedogg's Avatar
Somebody has a hot combo somewhere.
Old 05-11-2012, 06:58 PM
garygnu's Avatar
I like the l92 heads ,but it will cost you more the cost of the l92 heads will be more then used 799s,and the need for off set rockers.the 799 route would be more budget friendly.get a ls6 intake and pick the cam that meets your needs.
Old 05-11-2012, 07:23 PM
kainedogg's Avatar
I will admit I am no longer a fan of the L92's at least in my friends combo. LQ9 with L92 heads and I forgot what cam. In a 71 Chevelle, a little chubby off the line but then it winds up and is off. I can't picture any combo worse for a heavy truck.
Old 05-13-2012, 12:56 AM
1988montecarloss's Avatar
you cant really blame that on just the heads, there are a lot of things tht could cause that (wrong cam, too high of rearend gears, not a high enough rpm stall converter etc.)
Old 05-13-2012, 01:15 AM
kainedogg's Avatar
I hear you 88, but finding the "right" combo maybe too expensive for trial and error. I know those heads flow tremendously, but you need more than that. He has 3.55 gears and a 2800 stall I think. The 22's maybe to blame as well, but the thing is so darn fast on the top end. I want a torquey 6.0.
Old 05-13-2012, 09:02 PM
SweetS10V8's Avatar
Budget?
Old 05-13-2012, 11:53 PM
Macs98Z's Avatar
He has 3.55 gears and 22's
3.55s with 22's? Geez, that would be a dog. And who puts 22s on a Chevelle?
Old 05-14-2012, 12:52 AM
x2 on that haha
Old 05-14-2012, 04:09 AM
bww3588's Avatar
You must have forgotten the l92 heads come stock on heavy *** trucks, so the Heads cannot be blamed at All.
The effective gear ratio is what's making at a turd. 22's and 3.55's...try some 4.10's in that chevelle and watch it come alive at about stall speed.
Old 05-14-2012, 06:59 AM
kainedogg's Avatar
Originally Posted by SweetS10V8
Budget?
That is a valid point...but didn't they come with variable timing. As for the truck, my budget is $2000. Maybe ported factory 243's, 4l60e and 3.08's in the rear is what I see right now. Cam choice is another factor.
Old 05-14-2012, 07:01 AM
kainedogg's Avatar
I would assume the same people who put LS motors in old school cars...because they felt like it.
Old 05-14-2012, 07:08 PM
99VetteFRC's Avatar
MAN, just use bone stocker and jam lotsa air in it!!!!
Old 05-14-2012, 09:01 PM
kainedogg's Avatar
...lol. Already doing that for the the Lemans. Want a plain jane torquey C10. You saw that twin-turbo kit for sale on Corvette forum? Top mounted...hmmm
Old 05-15-2012, 04:45 AM
99VetteFRC's Avatar
No I didn't. I'm not on any Vette Forums.
Old 05-15-2012, 06:25 AM
kainedogg's Avatar
Well you should join it, especially if you are still modding the C5. I got a great set of sports seats off there and a lead on a cheap trans.
Old 05-15-2012, 06:41 AM
97badass's Avatar
You need a lot more than a 2800 stall
Old 05-16-2012, 04:01 PM
kainedogg's Avatar
Why is that? I have a car with a 3200 stall now and it sucks monkey ***** with the 3.15 gears.
Old 05-19-2012, 02:50 PM
kainedogg's Avatar
No more answers?
Old 05-19-2012, 03:11 PM
formerly 2000blackcamaross (6-25-2013)
LSGUNSS's Avatar
I would do:
Stock 6.0 cubes
MILD Cam 223/223 .571/571 114
L92/LS3 heads
LS3 intake
ARP bolts to hold it together
What trans/stall combo are you going to run? What is your budget?
Quick Reply: What if you had a cheap iron headed 6.0
