DrSpeed
05-11-2012, 01:50 PM
Fluidampr Harmonic Balancer Installation Cadillac CTS-V
https://lh5.googleusercontent.com/-99Yek4Ase6w/T60Lz0oMh7I/AAAAAAAAH0Y/dcZIt79KpIY/s512/Title.JPG
Everyone loves a motor that purrs. The factory does a fantastic job of making modern cars idle buttery smooth even high performance variants (such as the V variants of the Cadillac models) are subject to the same standards. When horsepower junkies get their hands on these high performance models, we feel that where the factory left off, is a great starting point for us. After a few modifications, the car is definitely outside the realm of factory specifications. The case with this V model, after the addition of long tube headers, new high performance LS7 clutch, and super stiff motor mounts, the buttery smoothness is all but gone, truly transforming this Cadillac into a 4 door Corvette. One of the primary drivers for installing the Fluidampr was to address the vibrations felt at 2,000-2,250 RPM with the mods, most likely brought by the UMI motor mounts. One of the key selling feature of the Fluidampr, from Vibratech TVD, a Horschel Company, is that it is made in the USA. The damper utilizes a silicone fluid between the damper housing and the inertia ring to quell the vibrations from the eight combustion events every two crank rotations.
The torsional damper works to prevent:
Crankshaft Cracking or Failure
Excessive Bearing Wear
Excessive Gear Wear or Failure
Broken Accessory Drives
Throwing or Slapping of Belts
Installing the Fluidampr on the 2004-2005 CTS-V with the LS6, requires your basic garage tools sockets, ratchets, pliers, screwdrivers, as well as a few KEY specialty tools and items:
LS specific harmonic balancer installer tool (balancer bolt is a 16mm X 2.0)
3-Jaw Harmonic balancer puller
Torque wrench with a 240+ ft. lb capacity
New OE harmonic balancer bolt (not a tool, but a must have)
GM approved Dex-Cool coolant (if you dont want to reuse the collected coolant)
Most parts-store balancer installation tool will not work with the LS motor, as the 16mm balancer bolt goes deep into the crankshaft. I did not realize that until I had the stock balancer off, and had to have a friend / Cadillac tech / fellow forum member bring his installer over (he had to go back to the shop to go get it). So, let that be a lesson learned for you guys. Also note this is a good time to replace the upper and lower radiator hoses since you have everything apart.
https://lh6.googleusercontent.com/-mviQNgwTZSM/T60LnGKcPwI/AAAAAAAAHww/nkTAxpn6efo/s512/IMG_0291.JPG
First step is the easiest part. Drive onto a set of ramps youll need to remove the undertray to access the lower radiator hose and decouple the AC condenser.
https://lh5.googleusercontent.com/-UW1aRqCY4n8/T60LnDpjc5I/AAAAAAAAHws/kWfxkByx4j4/s512/IMG_0293.JPG
After removing the front engine cover to expose the radiator, undo the bolts that secure the radiator (circled in red) to the core support.
https://lh3.googleusercontent.com/-HBChOdHVCIA/T60LqcKkFxI/AAAAAAAAHxk/8q2EWYzl3OA/s512/IMG_0299.JPG
Remove the air intake tube from the filter to the throttle body. Then grab the pliers and remove all the coolant lines into the radiator (circled in red).
https://lh4.googleusercontent.com/-ws-JrV5Kqdc/T60LqwXjiVI/AAAAAAAAHxw/MOH_lLTBG0g/s512/IMG_0300.JPG
Then separate the AC condenser from the radiator. Two of the four bolts are circled in red.
https://lh3.googleusercontent.com/-gAhoXZdIuyI/T60LpA69_5I/AAAAAAAAHxM/sXZu9ZCywk8/s512/IMG_0295.JPG
A pair of dykes (cable cutters) are used like the back end of a claw hammer to remove the push pins that secure the bottom tray to the V. Use it pry, not to cut.
https://lh5.googleusercontent.com/-TberEoH1Pu0/T60LphRloDI/AAAAAAAAHxc/baWLuORfnKE/s512/IMG_0297.JPG
Slide a catch pan underneath the V, and disconnect the lower radiator hose. Be prepared to catch the coolant, or take a bath!
https://lh3.googleusercontent.com/-p3kgEMtEZHk/T60Lq23Sg0I/AAAAAAAAHxs/sQLxqvYPd48/s512/IMG_0301.JPG
After the coolant is drained, remove the lower AC condenser bolts, unhook 1 AC line clamp, and 2 fan electrical connectors, freeing the radiator from the car. Note the red circles indicate the AC condenser attachment points.
https://lh6.googleusercontent.com/-AHjzNbqwDfU/T60LsID4AvI/AAAAAAAAHyE/ZEe6tF8wQZ4/s512/IMG_0303.JPG
Put a ratchet up to the two tensioners to remove the main serpentine belt and the AC belt.
https://lh3.googleusercontent.com/-0FEoP33osvY/T60Lsr-nh_I/AAAAAAAAHyM/hDJiBQjaCPA/s512/IMG_0304.JPG
Put the Caddy in gear, set the parking brake, grab a socket, and the biggest breaker bar you can find. Throw a fender cover or towel over the right side fender, and pull back with all you got. It will rock the car when you are breaking the bolt loose, but keep going. Keep the original bolt, as youll need it later. Note some oil will weep out of the hole when you pull he bolt.
