Need help on my build up list.
Got some lifter isssues going on, so it's now time to build. What are some good companies out there that are strict LS performance. Need lifters, pushsticks, rockers (aluminum/steel w/e) and of course a nice cam. This is the first stage. Here is the car information 2002 Z28 Camaro, all stock 5.7L 64,000 miles, stock 241 heads. Car is all original and it needs some unstock badassness in it's life. Ohhh and gonna need some headers as well, I have PO420/430 so it's time for some deletion.
LS7 lifters are a good choice and have a tight budget or if you plan on moving up to real high performance stuff, then look at the Lunati link-bar lifters. For rockers, I would just do the Comp Cam trunion upgrade. Cam, valve springs, and pushrods can be found bundled together in a cam kit if you check out Texas Speed.
