2004 5.3l with DBC and feed/return rails??
So I'm considering picking up an 5.3L
From an 2004 Avalanche. Said it had 40k when it was pulled.
It has 862 heads
The intake is there but no throttle body, looks like it had an drive by cable cause it has the mounting points for drive by cable bracket on the intake.
Then it has feed and return style fuel rails. I thought they switched to returnless style in 2004 on the fuel rails for truck motors??
The motor is complete except it has a broken oil pan on it from transport from Kansas to here in California..
It needs an harness cause the harness was cut
Also needs and ECU
Should I look for BLUE/GREEN harness and computer or BLUE/RED. I'm sure it doesn't matter really as long as the harness and computer match.
It has 862 heads
Also needs and ECU
