Drag Racing Tech - torque arm talk
Leeroyws6
05-13-2012, 09:59 AM
if all i want to do is go low 7's or possibly high 6s.will an aftermarket tranny mounted torque arm be sufficient? or should i get one that mounts to the crossmember?
Leeroyws6
05-13-2012, 10:32 AM
read the sticky.going with a short one that mounts to chassis.weld in a dedicated crossmember just for TA support.
RARON455
05-13-2012, 01:42 PM
Even on stock power, YOU NEED to get that arm off your trans.. Period. that was a bad Idea on Gms part..
one fast zo6
05-13-2012, 02:00 PM
you mean in 1/8 mile right?
Leeroyws6
05-13-2012, 03:45 PM
HAHA! yeah man, 1/8th mile. im not that serious of a racer.just wanna go low 7s or high 6s in the 1/8th mile.ive never evan ran the quarter.(we dont have one around here)
BAMALS1
05-13-2012, 09:25 PM
Yea, like others have said crossmember mounted should have been factory.
ssvert99
05-14-2012, 10:36 AM
Body mounted arm works great in your power range. Check out the one MWC makes here...works great on street and track and is priced very affordable. Comes in a powdercoated finish and includes a driveshaft loop at no extra cost.
http://www.midwestchassis.com/torque-arms.html
HioSSilver
05-14-2012, 11:55 AM
I run lower 7's on the stock tq arm. I haven't wanted to change becuase of the noise people have said the aftermarket arms make.
355z28
05-14-2012, 12:51 PM
Mainly with the short Arm. I run a BMR full length with a remote mount cross member and its not any louder then stock. I was running 7.20s at that time.
Fbodyjunkie06
05-15-2012, 08:32 PM
I run the Madman Extreme Chromoly chassis mounted(dedicated tq. arm mount) with the slider nose on mine.
Love it wouldn't use any other.
I had a solid mounted spohn with a body mount and fixed clam shell nose and it clunked more than this rod ended solid mount does I have now.
gillbot
05-15-2012, 09:25 PM
I'm in the lower/mid 7's on the stock torque arm.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
