what lifters are these
Old 05-13-2012, 10:41 AM
Turd Gen Guy
1nasty86's Avatar
Default what lifters are these
i bought a set of lifters from a member on here and were told they were ls7 lifters... but the p/n does not match up.. the lifter p/n on the box is L2148-16
Old 05-13-2012, 10:50 AM
badazz81z28's Avatar
A quick google search showed them to be universal for various years.
http://www.store.partsdinosaur.com/product1166.html
Old 05-13-2012, 10:55 AM
PREDATOR-Z's Avatar
SBC Chevy V-8 Hydraulic Roller Lifters
L2148-16 -ET
OE-replacement style hydraulic roller lifter from Enginetech for the following GM engines:
87-93 Chevy 4.3 cars VIN "Z"
94-96 Chevy 4.3 cars VIN "W"
87-02 Chevy 4.3 trucks V-6
88-92 Cadillac 4.5 V-8
99-09 GM / Chevy 4.8 trucks V-8
91-95 Cadillac 4.9 V-8
87-93 Chevy 5.0 cars V-8
96-02 GM / Chevy 5.0 trucks V-8 (all)
99-09 GM / Chevy 5.3 trucks V-8 **
-- ** except cylinders with "displacement on demand"
87-93 Chevy 5.7 cars V-8
96-02 GM / Chevy 5.7 trucks V-8 (all)
92-97 GM cars 5.7 VIN "P"
05-09 GM cars 6.0 V-8 all
99-09 GM trucks 6.0 V-8 all
(for use with roller cams only) Please note that this lifter is also used in a few other applications not listed here.
(Price listed is for one set of 16) (removed not to infringe on LS1tech posting rules)
Old 05-13-2012, 10:57 AM
I suspect not only NOT LS7, but not LS at all... Sorry to say
Turd Gen Guy
1nasty86's Avatar
well... will these lifters be good for 7000 rpm? i have already put these lifters in my engine and didnt think anything about it... if these wont work im not gonna be happy
Old 05-13-2012, 11:35 AM
Turd Gen Guy
1nasty86's Avatar
Old 05-13-2012, 05:41 PM
kmetros's Avatar
Did you use a push rod length checker to determine your rod length or did you install something that came with a kit? What size were they?
Not sure how you would find the max rpm on these. Did they fit into the lifter trays fine?
Old 05-13-2012, 05:54 PM
Turd Gen Guy
1nasty86's Avatar
Im not worried about pushrod length... I ordered "ls7" lifters from a member on here and this is what I got... they fit the ls2 lifter trays perfect
Old 05-13-2012, 08:41 PM
therabidweasel's Avatar
Dude, not being an ***, but if you don't know what lifters you've installed you damn well better be worried about pushrod length...unless youve already started and not destroyed it.
Old 05-13-2012, 09:27 PM
Turd Gen Guy
1nasty86's Avatar
Well I was told from the guy I bought my trickflow 225's from that I needed a 7.500 pushrod to achieve good lifter preload and since the post above clearly states that these lifters can and are used in ls car and truck engines id ASSUME that a stock headed ls engine that required 7.400 pushrods that I would be fine with my 7.500 pushrods since the deck of my trickflow heads is thicker... Hence me only asking if they will be good for 7k rpm instead of what pushrod do I need
Old 05-13-2012, 11:04 PM
Turd Gen Guy
1nasty86's Avatar
Ill be contacting engine tech tomorrow and checking in on this
Old 05-14-2012, 10:17 AM
Turd Gen Guy
1nasty86's Avatar
Yeap... These are stock replacement lifters and not ls7's which have a different bleed down rate apparently...
Old 05-15-2012, 06:01 PM
Turd Gen Guy
1nasty86's Avatar
well went ahead and purchased "ls7" 12499225 lifters and compared the "ls7's" to the engine tech ones.... ls7's left and engine tech's are on the right
Old 05-15-2012, 07:56 PM
vettenuts's Avatar
There are only a couple of lifter manufacturers (Eaton, etc.) but not sure who makes the ones in your hand.
Old 05-16-2012, 12:12 AM
slammedc5's Avatar
Hum, they almost look the same. Just different casting shapes around the upper hole. Cant speak for the internals.
Old 05-16-2012, 06:03 AM
kmetros's Avatar
Originally Posted by 1nasty86
Well I was told from the guy I bought my trickflow 225's from that I needed a 7.500 pushrod ......
Yes, and I was told by the company that I bought my cam package from that I needed a 7.425 push rod. I actually measured and needed a 7.350 push rod. Had I just installed what someone 'told' me to I would be in your boat.....trying to figure out what's wrong with what I've already installed. Oh, and then when people tried to help me I would tell them that I have measured nothing but they must be wrong because the person that sold me these parts that I don't understand or trust told me something else.
Someone please explain this to me? Oh, and while someone is explaining this to me the OP should go out and buy a $22 push rod length checker to ensure that he doesn't destroy his $3K engine with $100 lifters that he knows nothing about.
Old 05-16-2012, 09:13 AM
Turd Gen Guy
1nasty86's Avatar
i have already ran this engine with the 7.500 pushrods and i was told by brian tooley that these were the pushrods i needed... enuff said...
Quick Reply: what lifters are these
