Gen 5 Camaro External Bolt-On Tech - LEDS on 5th Gens
Midnight00SS
05-13-2012, 06:15 PM
Come in, anyone that has info and or pics, i appreciate it
Midnight00SS
05-15-2012, 10:36 AM
anyone know how to replace the sidemarker bulbs in the front and back?? is there an access panel?
Dark SS
05-15-2012, 10:46 AM
It pops out of the fenders. Pry on the back of the lens and it should come out.
Midnight00SS
05-15-2012, 11:04 AM
yea but how do u get to the back of the lens from inside the fender?
Dark SS
05-15-2012, 01:15 PM
You don't, you pop out the entire lens assembly and twist out the bulb.
Midnight00SS
05-16-2012, 04:17 PM
and it doesnt break by doing that?
Mr JB
05-17-2012, 06:01 PM
There are 3screws inside fender take those out and you can pull back plastic liner to access light there is a tap attached to light u push it out with flat panel popper and light pops out if u try to pry it out from outside you may or may not break it this way it comes out as designed to Disconnect light and replace with new one which snaps back inn takes bout 10mins to complete...
Midnight00SS
05-17-2012, 09:53 PM
wut is a flat panel popper?
Dark SS
05-18-2012, 07:55 AM
Nope, I swapped mine out a couple times and never broke one. There is a tap that slides into the fender on one side. If the light doesn't just pop right out, pry on the other end. I used a flat head screw driver with electrical tape wrapped on the tip.
Midnight00SS
05-27-2012, 09:00 AM
alright im gonna give it a try and see, hope it goes well lol
Midnight00SS
06-05-2012, 11:59 AM
how the heck do u get to that light in the rear fender lol?
Midnight00SS
06-07-2012, 04:20 PM
are u bottom running lights a p13 bulb on the 2012s>??
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
