Anybody use a stock mustang tach?
Old 05-13-2012, 09:22 PM
sum guy's Avatar
Default Anybody use a stock mustang tach?
I'm wiring an ex four cyl, 86 mustang with an ls1 from a 01 camaro. Using factory mustang gauges. I have all of them functioning ,but the tach. I hooked the tach out put from the pcm to the correct wire on the gauge cluster but it doesn't work that way. The mustang gauge uses a signal from the negitive side of coil. Any body know what kind of signal exits the camaro pcm? If anybody has made this work lets here it.
Old 05-14-2012, 06:39 AM
chiaj144's Avatar
Did you go into the tune and change the tach output as the LS PCM outputs a faster tach signal than the 'stang tach wants."
Old 05-14-2012, 08:54 AM
boostnut's Avatar
From what I've read there really isn't any reason to use the stock mustang tach, it's not even close to accurate.
Old 05-14-2012, 09:21 AM
Chrome_Rust's Avatar
Unless you are like me and want all the factory gauges to work. I dont like the look of aftermarket gauges cluttering my interior.
On the tach inself under the trim panel on the tach itself there should be a little switch that sayd 4-6-8 and a flathead screw that will allow you to turn it to the correct number of cylinders. If memory serves me the GM PCM outputs a 4cyl tach signal, so you should be ok there. Just wanted you to have that info.
Some people have to use a pull-up circuit to make the signal work.
try that. hope it helps.
Old 05-14-2012, 09:39 PM
zipster's Avatar
Correct on the tach not being accurate, but there are trim pots to calibrate them on the back side. I am using the factory v8 tach, had the tuner change the output. I did not need the pull up resistor. I also wanted the OEM look, no aftermarket gauges except the wideband next to the column on the cluster bezel.
Old 05-14-2012, 09:46 PM
sum guy's Avatar
So you hooked up the pcm out put to the mustang pigtail and it worked? Starting to second guess if they were compatable.
Old 05-14-2012, 09:48 PM
sum guy's Avatar
I'm going to try this. Thanks
Old 05-19-2012, 03:56 PM
zipster's Avatar
Mine works, I connected the tach output from the computer right to the tach wire in the dash. My tuner changed the output to allow the stock tach to work.
Old 05-19-2012, 09:54 PM
Steve01SS's Avatar
He has an 86, I used to have one as well (stock 5.0). It has a different dash and gauges than a 93. They changed the dash in 87. He may need the pull up resistor.
Quick Reply: Anybody use a stock mustang tach?
