Pontiac GTO 2004-2006 - Cluster mpgs
View Full Version : Cluster mpgs
youngbuck
05-14-2012, 10:01 AM
If the mpg calculator on the cluster very accurate? Just curious if my mpgs are as good as it says sometimes lol. 04 a4 with stock size tires.
NicB
05-14-2012, 10:06 AM
What does it say?
gconnoyer
05-14-2012, 10:17 AM
Stock tires, gears, injectors?
youngbuck
05-14-2012, 10:50 AM
Yea all stock. Has cai , tune, straight exhaust with borla mufflers. City will be between 16-21 depending how hard I drive it, around 24 on the highway.
NicB
05-14-2012, 11:42 AM
With easy driving I can get about 18.4 city and 25-27 highway on 93 octane. But that's with a m6 z28. But same motor. I believe gto's weigh a bit more. But I would say its fairly accurate.
409CISecondGen
05-14-2012, 11:53 AM
That what I get with same mods + 3.91's
youngbuck
05-14-2012, 12:09 PM
I was just curious if anyone elses reads high or if they are accurate.
gconnoyer
05-14-2012, 02:37 PM
Should be pretty damn accurate.
Figured out by mileage/fuel used (based off injector pulse)
gmantheman
05-14-2012, 04:07 PM
I thought hwy would be 20-21 for an A4.
Jake8493
05-14-2012, 06:20 PM
I just Drove 2000 miles of interstate across the country in my 04 A4 GTO and I got 20-21 mpgs the whole way pretty much on 93 octane
svede1212
05-14-2012, 09:25 PM
The only way to really tell is to fill up, note miles, drive, fill up again and do the math. Injectors can really botch up the calculations. I'm about 13% off but it doesn't matter. It is what it is.
impulsegoat
05-14-2012, 10:49 PM
@ 70-75mph and turning 21-2200 rpms you will see around 21-20 mpg in an A4. Knock it down to 60mph @ 1800-1900 rpms and it jumps up around 24-25mpg.
youngbuck
05-14-2012, 11:19 PM
I normally just figure the mileage to gallons used but it's hard to get the same amount of gas in every fillup in the goat. Certain pumps won't even fill it up all the way!
mild83
05-15-2012, 11:26 AM
I'm glad someone else has this problem. Sometimes, I can only fill up to 7/8 tank. It's weird, never had that problem before.
ACCLR8N
05-15-2012, 11:31 AM
When I checked mine manually it was always within 0.3 MPG of the gauge. I chalked that up to not being able to fill it exactly the same. I would say it is quite accurate.
gmantheman
05-15-2012, 12:06 PM
I had the same issue with my mustang and now with the GTO. You may already know this but you need to do is rotate the pump-handle to about an 80 degrees towards the rear of the car.
smitty2919
05-16-2012, 02:00 PM
Sounds about right. My 04 M6 is gettimg best of 24.5 highway on a 2 hr trip CC set at 70mph
