Generation IV External Engine - side exit exhaust ?'s
View Full Version : side exit exhaust ?'s
Project_Reaper
05-14-2012, 02:11 PM
just wanting some opinions from you guys on a choice of mufflers..so the old setup was slp LT headers with a 3in y-pipe into a 3in loudmouth Bullet II muffler into dual 3in axel back....Sounded great but had a little rasp to it but it was heavy..so the current setup is the same headers with only 22in long 3in header extensions with 45 degree turn downs which saves alot of weight and gave a nice increase in top end HP while still retaining TQ....Sounds great but its pretty darn loud...so here is my plan now.....The headers straight into a muffler then into side exit exhaust in front of the rear tires. so im just wondering what would be the best muffler that would have very little back pressure, good sound with little to no rasp....i was thinking Corsa, or Borla..not sure..whats ur guys opinions?
bwkmaro
05-14-2012, 02:24 PM
borla is a good choice but the prob is with side exit exhaust how are you gunna get it on a lift if needed? i wanted to do the same and ran into this issue. i ended up dumping it as close to the rear axle as i could(actually cut a 1/4 off the turn downs so it wouldnt rub the axle) and i sound deadened with sum 1/8" roof sheathing. worked great sounded great was light and wasnt too bad inside the car
Project_Reaper
05-15-2012, 08:01 AM
okay appreciate the input tks....okay so Borla is still on the table as a canidate..HEY bwk do you have an exhaust clip that i could hear?
babbage1109
05-15-2012, 08:08 AM
Dr gas sells side exhaust tips. Some have mufflers built in. And you cut to fit
1CAMWNDR
05-15-2012, 08:14 AM
It's been talked about for years and tried several times but there just isn't enough room in that area for 3" pipe and a decent muffler.
bucketobolts
05-15-2012, 08:17 AM
Boom tubes...;)
babbage1109
05-15-2012, 08:19 AM
Dr gas= boom tubes
Project_Reaper
05-15-2012, 07:56 PM
ive got 22in long 3in header extensions right now with 45 deg turndowns and from what space i have it looks like i could cut in a round 4in glasspack style muffler like my old SLP loudmouth bullet II muffler or a nice Corsa
Project_Reaper
Dr gas= boom tubes
ive never heard of these ill have too look em up
bucketobolts
05-15-2012, 08:48 PM
http://image.popularhotrodding.com/f/project-cars/1975-laguna/16403732/dr-gas-exhaust-on-project-talladega.jpg
Dr. Gas FTW...:hail:
85CamaroZ28
05-15-2012, 09:14 PM
That's pretty bad ass
FinallymyT/A
05-15-2012, 09:25 PM
That looks killer!!:guns:
Project_Reaper
05-16-2012, 07:06 AM
that does look pretty freakin sweet!..im just curious on how it sounds..cant be any quieter than my header extentions now?:confused:
bww3588
05-16-2012, 08:51 AM
you would be suprised, they are more than just fancy flat tips. they are actually mufflers in themselves.
SSCamaro99_3
05-16-2012, 01:50 PM
Maybe my eyes are not working. Is that an F-body, and iff so how is it attached at the edges of the body, and is the fuel line shielded.
Project_Reaper
05-17-2012, 07:10 AM
i think i might be buying one of these DR.GAS setups, im sure not a whole lot of ppl have them
Project_Reaper
05-18-2012, 07:03 AM
just watched a video last night of the DR GAS Freq Mod mufflers....i think ive found the ones im gonna use :)....headers straight into a freq mod muffler on each side (true duals) then out of the freq mod into a short 6in long 3in 45degree turndown just befor the rear tires...should sound epic after the H/C setup
notnilc20
11-07-2012, 12:03 AM
Did you ever do this??? I was thinking of doing the same thing. Thanks
