Stereo & Electronics - Hit Bump... everything stops workings.
00Z28 ls1
05-14-2012, 06:48 PM
as the title says, when i hit a bump my stero stops working but the weird thing is when this happens the windows will not go up or down. this just started today when i hit a bump i can do this to my gently smacking the dash above the cd player. where or what could my issue be? connection on back of my cd player seems good, its factory btw
JOHNNY59
05-14-2012, 07:48 PM
check for bad solder joints on the BCM board.
00Z28 ls1
05-14-2012, 07:49 PM
ok . will try if there are what do i do just resolder them??
SparkyJJO
05-14-2012, 08:01 PM
Yep, reheat + a little fresh solder and you're done. Common problem, easy fix.
http://i58.photobucket.com/albums/g270/SparkyJJO/Car/BCM.jpg
00Z28 ls1
05-14-2012, 08:12 PM
ok thanks, found a old thread with everything about this... will be fixed tm.
00Z28 ls1
05-15-2012, 10:10 AM
ok i did this it fixed the windows/ stero but the light on my radio that shows station/ time is still dim??
SparkyJJO
05-15-2012, 02:06 PM
Possibly a blown backlight bulb in the deck itself. Unrelated to the BCM.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
