Black96z28
05-14-2012, 07:59 PM
I recently received my kit from Blackbird Lighting Solutions. A lot of people on here have the opinion that it is too much money to spend. I personally believe that these were worth every penny. Daytime Pics in Post 7, Night pics in Post 15. High Res of any of the pics available.
The main kit that they send you is easy to install. You have one power and one ground that you attach to the proper posts. You have one place to plug in factory harness and two outputs at the ballasts. Awesome quality components and they even put the wires in a sheath.
The amount of work that you need to do to remove and install the headlight assemblies is minimal. You take the bracket at the top of the light assembly that attaches to the core support off and slide the assembly towards the middle of the car and pull out.
The hardest part of this will be deciding where to put the components of the HID's. If you use my suggestions, you could probably install these in 30 minutes.
I chose to put my relay block down on the fender support on the drivers side. I put my ballasts in the same spot on both sides, right behind the inner most part of the light, where the core support, bumper support and headlight bracket attach.
If you use my suggested locations, you will not have to make new holes to mount the kit as I used stock fastener locations.
The tools I used were:
10mm socket
15mm socket (just for the positive post on drivers side)
3/8 drive ratchet
More pictures tomorrow, Its dark and raining right now... Before you ask, pics are before being aimed correctly.
http://www.the3rdhonk.com/lsx/blskit/DSC_0346.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0347.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0349.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0351.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0352.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0353.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0356.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0357.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0362.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0364.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0365.JPG
http://www.the3rdhonk.com/lsx/blskit/DSC_0366.JPG
10mm socket
3/8 drive ratchet
