General Maintenance & Repairs - 01 WS6 very Rough idle, missfire on all cylinders.
ccrook19
05-14-2012, 09:04 PM
I have a 01 trans am ws6 with a T56.. car has about 53k miles on it bone stock i think.. it has no codes
no cracked vacuum hoses
New plugs and Wires
02 sensors are switching like they should and are not SLOW
it misfires at idle on "ALL CYLINDERS"..
any idea's??
ccrook19
05-14-2012, 09:06 PM
It has more then enough power and no misfires anywhere else but IDLE
DisasterFormula
05-14-2012, 09:40 PM
Try cleaning the maf, IAC, check voltage on the TPS.
lynx853
05-14-2012, 09:42 PM
had the same problem after it sat for a month. Going to say the ethanol in the fuel absorbed water like mine did, drain the tank and put fresh gas in. I was chasing that gremlin for a few days.
MurderedOut
05-14-2012, 10:14 PM
check for vacuum leaks and check the intake gasket. Ive had small leaks in intake gaskets cause small misfires on only one or two cylinders sometimes all, only at idle. the second you hit the throttle it goes away.
ccrook19
05-15-2012, 11:42 AM
Maf was cleaned multiple times, along with swapping with a known good one.. Iac on the scanner seams to act perfectly fine.. but haven't cleaned it at all.. and if there was low voltage to the TPS a code would be thrown right away...
