EPS 226/230 Cam and ARH 1 7/8 Install Questions
As the title says, I'm installing an EPS 226/230 cam (and cam package with new pushrods, dual valve springs, and titanium retainers) and ARH 1 7/8 headers in my 2002 SS in a few weeks. I'm planning on getting the stock 241 heads professionally hand ported and a 3 angle valve job by a local expert to save $ from sending them to get a CNC job.
The drive train is stock except for a Monster level 2 clutch, lightweight flywheel, rebuilt transmission, and Tick master cylinder. The motor has about 50,000 miles.
I have been reading about throttle bodies, intakes, and MAFs for a few hours.
I figured I'd look into getting a new 85 mm MAF (probably a used GM one from eBay), a new 85 mm throttle body (because I think it would be better overall than porting the stock throttle body), and porting my ls6 intake to match the heads and throttle body (the guy who is doing my heads offered to do the intake and he's done work on them before).
Questions:
1. Are the MAF, 85 mm throttle body, and/or ported ls6 intake worth it for this setup? In this thread, a sponsor stated that he has seen improvements from porting ls6 intakes, especially on cars with z06 MAF and BBK TB. https://ls1tech.com/forums/generatio...s6-intake.html I'm just asking because if there's a good possibility that it's going to be a PITA to tune with that work, and the gains on my car minimal, then I probably won't mess around with it.
2. Would it be a good idea to get bigger fuel injectors? If so, what size?
A few other things I plan on doing are: trunion upgrade, new timing chain, and new spark plugs and wires.
Would y'all recommend I do anything else?
The car is my daily driver, and I autocross. I'm just trying to get some more power with the stock bottom end, and not trying to spend too much money but get good results.
Any help would be appreciated.
Questions:
Id ditch the MAF idea. Stock is fine with your setup. IDK about the throttle body/intake porting, I have no experience with those. I went from a stock LS6 to a FAST.
For injectors, 28s would be fine, you may already have them depending on the year of your car.
Id upgrade the oil pump while your in there. Maybe thinner head gaskets? Compression is your friend.
Yeah, the MAF may be more of a hassle than it's worth.
My car has the 28 pound injectors. With the cam and ported heads, they won't be maxed out?
I'm still not sure if I want to mess with the compression with milling the heads and/or different head gaskets.
As a follow up to this,
1. I ended up getting 36 pound/hr. injectors.
2. I did not port the ls6 intake, but I did a little cutting around the filter box, it's a factory SLP Blackwing, but there was some restriction on the lower plate. I don't know if it made much difference, but I figured it wouldn't hurt.
3. West Coast Cylinder Heads Stage 2 243 heads, with BK springs and titanium retainers. Beautiful cylinder heads.
4. CNC ported VMAX throttle body. A lot snappier response. Excellent product.
I'm happy with the final dyno numbers - 432 rear wheel horsepower, 399 rear wheel ft./lb. torque. The car runs great, the cam has a great power band, and according to the tuner all the numbers look good. There is some bucking just above idle and around 1500-1800 RPM, but that is probably worse because I have a lightweight flywheel. Overall, I'm very happy with the end result.
