Gears & Axles - 8.8 ABS ring..
View Full Version : 8.8 ABS ring..
jman54002
05-15-2012, 11:36 AM
has anyone gotten the ABS ring on a 8.8 conversion to work with the ABS of a 3 channel system in there cars?. I would like to keep the factory ABS system on my car. 02 trans am. the Ford 8.8 has a ABS system on it. And I would like to use it but it has a diffrent tooth count ..off by two.
t/a98
05-15-2012, 01:21 PM
Yea I've read where a couple have no problem. With machining the 8.8 ring will fit some 9" differentials. I have read some people have problems but I'm not sure why. If you run the same size tire or slightly taller the computer should compensate. It mainly looks for quick changes between front and rear not constant.
jman54002
05-15-2012, 02:23 PM
thanks for the reply ..
