Opinions on log. (HPT)
Old 05-15-2012, 03:17 PM
WeakSauce6's Avatar
Default Opinions on log. (HPT)
So I did a quick log today to get started, and after making several trips working out bugs I got a short log with a WOT pull. I'd like to get some peoples opinions on it. Getting lots of knock up top, but I'm guessing its from my crappy 98 knock sensors. Mods are as follows, 98 Trans Am M6 with 1-7/8 lt's, ory, magnaflow cat back, ls6 intake, lid, 9" with 3.89 gears, and just installed BR7EF plugs in prep for a 150 shot. Thoughts?
File Type: hpl
Old 05-16-2012, 05:07 PM
WeakSauce6's Avatar
82 views and no input?
Old 05-16-2012, 09:00 PM
speedfreak2685's Avatar
Looks like you are seeing a decent amount of knock at WOT? Im a newbie too so just starting to learn.
Old 05-16-2012, 09:57 PM
MontecarloDrag's Avatar
It's lean when you enter WOT, richen it to 12.4 AFR (set power enrich EQ ratio to 1.18)
Lower all power enrich enablers to a point where it will react faster, like RPM 100 and MAP to 10.
I think you are having burst knock and not real knock. Is this with 91 octane?
Disable all burst knock and log again.
It appears you are running out of injector, are they stock?
Don't try the shot yet, too risky with you current tune.
Post your tune file too
Old 05-17-2012, 06:08 AM
WeakSauce6's Avatar
This is the tune that was in the car. The only thing I've done so far is adjust the speedo for gears, turn of the rear 02's, AIR, and EGR MIL's. Thanks for your input guys.
File Type: hpt
Old 05-17-2012, 06:49 AM
Brad Campbell's Avatar
Monte the injectors certainly do look max'd. I would say it isn't burst knock as it's logging under knock retard and not burst knock. I feel as though your timing map is veeeryyy sporty. I would be more sensitive to timing values especially at peak torque. You should take a closer look at your afr error to get your VE in check.
On a side note what is going to control your timing with your 150 shot?
Old 05-17-2012, 11:15 AM
WeakSauce6's Avatar
Was planning on doing the IAT resistor thing. As soon as the rain stops im going to start fresh with the stft's and get that as good as I can. Then I will start looking into the spark. Funny thing is I thought the car was all stock except the bolt ons I had done, but comparing my current tune to the stock 98 in the repository, its much different.
Old 05-17-2012, 11:20 AM
WeakSauce6's Avatar
Also, can you guys explain how to filter a histogram? I know you use a code, but I have no idea how to figure that out. I want to filter out when im decelerating from wot pulls.
Old 05-17-2012, 11:26 AM
smokeshow's Avatar
What do you want to filter out?
Old 05-17-2012, 12:48 PM
WeakSauce6's Avatar
I read some where that the fuel table can be effected by deceleration and needed to be filtered out.
Old 05-17-2012, 05:24 PM
smokeshow's Avatar
In your histogram configuration, in the histogram you want to filter, enter "[PID.17]>99". That is assuming TPS is PID 17, you may want to double check. That will filter out all throttle below 99%.
Old 05-17-2012, 05:30 PM
WeakSauce6's Avatar
Thanks. I got some good news today. A friend of a friend just opened a shop with a dyno that is going to let me tune my car on it for next to nothing so he can get a good look at HPT. I'm still going to work on it street tuning over the next few days to make sure I understand everything before I go.
Old 05-17-2012, 05:32 PM
smokeshow's Avatar
Cool deal man. That's a good friend to have
Old 05-17-2012, 05:42 PM
WeakSauce6's Avatar
Man I'm sorry for asking so many questions, but how do I confirm TPS is PID 17? I've been looking and can't find it.
Old 05-17-2012, 05:44 PM
WeakSauce6's Avatar
Never mind, found it right after I asked. lol
Old 05-17-2012, 05:47 PM
smokeshow's Avatar
Was it 17?
Old 05-17-2012, 05:48 PM
WeakSauce6's Avatar
Yep. Now I could do that with any sensor or PID, right?
Old 05-17-2012, 06:19 PM
smokeshow's Avatar
Yes. Just have to set the filter parameters to be what you want. And I think it goes without saying that that PID or sensor must be used in that particular histogram
