Chevy II
05-15-2012, 03:29 PM
OK, here is what I have:
5.3 from a 2004 Tahoe, stainless steel tank with a stock f-body fuel pump installed. I am going to use the truck manifold.
Here is what I have been told by a shop that specializes in LS-1 installation in older Corvettes:
Run a -6 fuel line up to the engine with an in-line filter installed. Before the filter install a tee and route a return line back to the return connection at the tank. The middle connection at the tank (5/16" dia ?) will be routed to a small vent filter. Use a vented gas cap.
At the engine, there are two connections at the fuel rail. One is 3/8", that is the feed line. The other line is 5/16" (?) and sets just above the 3/8" line. Is that suppose to be the return line to the tank? Can I cap that if I am running the return like I explained up above?
I am hoping one of the fuel experts here can tell me if this is a good plan, and hopefully tell me what the small connection is at the engine fuel rail.
Thanks for the help.
