Dynamometer Results & Comparisons - 2001 T/A with an Ls3 416 stroker!
View Full Version : 2001 T/A with an Ls3 416 stroker!
litle88
05-15-2012, 04:30 PM
I got my Dyno day at StraightLine in New Lenox Il tomorrow. They have a Mustang Dyno and the Tuner will be Mike.
I have an
*Ls3 Stroker with a Scat crank,Eagle H-beam rods and Manley pistons with -2cc valve reliefs
*C5r timing chain
*Morel linkbar street lifters
*comp 7.375 pushrods
*LPE polished and ported Ls3 heads with 65cc chambers to put my compression at 12.0
* cam is a LSR lobe by comp and it is a 243/259 .624/.624 114+3
*FAST 102 with the runners matched to the heads by my friend chriss1313
*Nick williams 102TB
*Stock Ls1 injectors resized to 65lbs (when using these injectors in an Ls3 Intake you'll need the narrower orings. and a few washers for the fuel rail to be able to get bolted down.
*kooks 2"primaries with a 3.5" collector with a kooks ypipe and dual lowprofile DMH cutouts to a magna flow C/B.
The car will be SD tuned and it has a 3" D/S thru a 9" and 4.11 gears with an M6.
I'm hoping I can get 550 as a number I was trying to acheive and that Ill be able to get a 10 sec slip with full weight, believe me Im not one of those guys that want a dyno queen in the garage, but it was just a goal to hit.
What are you guys predicting?
Thanks
Zeke
bluestar435
05-15-2012, 05:05 PM
When u say mike, would that be mike post?
djfury05
No way your getting 550 on a Mustang.. I'd guess 490-500
litle88
05-15-2012, 06:08 PM
Mike Post?
Hell no Mike from Straightline, I don't want to throw his last name out there. He's been tuning a very long time.
litle88
05-15-2012, 06:09 PM
Dj! No love hu? Lol
djfury05
05-15-2012, 06:49 PM
Dj! No love hu? Lol
I'd much rather hope for less and receive more in return lol.. Just trying to be realistic based on what others have made and doing it on a Mustang is like 15-30 less than a Dynojet most the time so who knows. Sucks to get your hopes up... I figured I'd make over 600 with my LS7 based on others but that didn't happen.
litle88
05-15-2012, 07:02 PM
Lol I know right? It's been almost 2 years in the making I've gotten all the good parts with no cut corners (do it once and do it right) method. I'm hoping for the best but expecting the worst lol. I really just don't want any hiccups or problems anymore , just my car back especially for the summer and running good!
s346k
05-16-2012, 10:11 AM
what fuel is the car on?
chrs1313
05-16-2012, 10:48 AM
525-535 on a m.d. Good Luck:cool:
NHRAFORMULA00
05-16-2012, 10:51 AM
Good Luck -ZEKE, that was my post above.
jzingre
05-16-2012, 11:16 AM
Sounds like a very well built combo. I need land from you zeke..... And these two guys above ^^^^ Did you have to extend the steering shaft to get the 2" kooks to fit without hitting?
1nasty86
05-16-2012, 11:47 AM
numbers?
litle88
05-16-2012, 01:46 PM
I will be using 93 octane
Chris thanks
Mr.Johnson Thankyou sir!
I didn't need to extend anything they fit right in sir, I do have a UMI tubular kmember though.
The car gets strapped down at 4:30 hp pulls around 6
Jimbo1367
05-16-2012, 02:18 PM
Who spec'd the cam? 480-520HP / 455-485 TRQ on a MD
fc3slsxpwr
05-16-2012, 02:22 PM
I predict 490-500 whp. I have a very simular setup. I have a LS3 stroker running a ls7 4.125 crank diamond pistons running a 5cc hump. SDPC Cnc ls3 heads. 12.9:1 compression. Fast 102 tb and intake running fast fuel rails with 60lb injectors. 1 7/8 primaries into dual 3 in mandrel bend exhaust running through a set of straight through mufflers and a x pipe. Car put down 505whp on our mustang dyno. Car has ran 10.52@135mph. Car weights in at 2700lbs. Ran a 1.58 60 with old drs.
This year I ported the intake and reworked the air intake. Hoping to see 520 whp and a 9 second time slip.
Forgot to add. I am also running a Comp LSR cam
The cam number is 54-474-11
litle88
05-16-2012, 02:41 PM
I was on the phone with an LsX tech for a few days back and forth and we came up with that spec and picked the LsR lobes
gs462
05-16-2012, 02:48 PM
What type of fuel do you run??
Detoxx03
05-16-2012, 06:24 PM
Waiting on numbers.
N2OBaby
05-16-2012, 06:35 PM
My guess is 460-480 RWHP.
djfury05
05-16-2012, 07:27 PM
its 8:30 EST what's the results lol
ctd
05-16-2012, 08:17 PM
Sensible Street DD combo :cool: :burn:
BOBS99SS
05-16-2012, 09:05 PM
Waiting for numbers
ZGLASS
05-16-2012, 09:28 PM
494/462 mustang dyno my guess.
litle88
05-16-2012, 09:49 PM
Sorry fellas ran into BIG FIGGIN problems. I don't want to talk about it til I have a word with Spohn tomorrow.
djfury05
05-16-2012, 10:23 PM
Driveshaft eh.. you've got me wondering what's up with it.. I thought my PST ds was out of round but it was the yoke and bearing caps not centered causing a drive line vibration. Hope you get it solved asap.
cranny
05-17-2012, 01:26 AM
Sounds like a great well thought out build. Regardless of what it makes, I'm sure it will be a blast to drive.
6D9 Matt
05-17-2012, 10:50 AM
Yeah being on a mustang dyno, Id guess 480-500 rwhp... 440-460 rwtq.
As most have said, its just a number... go out to the track and see what it can really do!
rpmauto
05-18-2012, 09:10 AM
Subscribing for results. I am building a 441 with ls3 heads, (wegner motorsports ported) Sleeved ls3 block, ls3 intake, and the same cam. A friend of mine just got done with a GTO and 441 ended up making 520, smaller cam, but has stock h-pipe with resonator, thinking that is the problem. Very curious on your results
litle88
05-18-2012, 10:00 AM
Well fellas here is what happens when using a Spohn, I contacted them and I told them what happened and I sent the pictures you see below and the you'll see their response. I ordered this d/s through the ws6store and as you can see I ordered the one that applies to me. Spohn's defense is you should of measured and that strapping a car on the dyno causes "stress" well no kidding but more that being on a street? Really? Well then if I have to measure why would they sell their d/s's as stock lengths? And ready to ship? Or th400's or 4L60's or power glides ? If you still have to measure?! I also called PST abd strange this morning and they said they DO NOT make theirs shorter! They both said they make it to exact sizes this Now I'm out a Trans with no days off because of these NATO clowns and All cops have to be on the streets or close by! All I wanted was to have my car ready by memorial day weekend to celebrate it with my family!
What do you guys think?
From tech@spohn.net
The output shaft on your transmission broke, it's actually a very common occurence when strapped down to a chassis dyno. A chassis dyno places a lot of stress on the drivetrain.
It had nothing to do with your driveshaft. The driveshaft is exactly as it should be from your pictures. They are supposed to be a bit shorter than the factory driveshaft, you need a little more slip yoke travel for high performance applications. This is how we have built them for 13 years and how any performance driveshaft company builds them. With that said it is always the installer's responsibility when installing any driveshaft on any car to check for proper engagement, etc. before driving the vehicle.
It was just a matter of the stress the chassis dyno put on your transmission, it happens unfortunately.
Here are the pics:
http://i214.photobucket.com/albums/cc127/litle8/71bfdfce.jpg
http://i214.photobucket.com/albums/cc127/litle8/a6b39bb3.jpg
http://i214.photobucket.com/albums/cc127/litle8/573f6ea0.jpg
http://i214.photobucket.com/albums/cc127/litle8/01bc65bf.jpg
djfury05
05-18-2012, 10:33 AM
FUCK SPOHN.. my buddy had their long torque arm with a 408 and it broke on the street.. All heavy garbage products..
djfury05
05-18-2012, 10:35 AM
Also, I say you get the 3.5" aluminum ds from PST. I have one and love it no issues. Warranted to 1000hp.
John Deere racer
05-18-2012, 10:44 AM
Ditto
1nasty86
05-18-2012, 10:47 AM
I use bmr for my suspension parts because of a conversation with a guy from spohn that he come off as being a prick so I called bmr after that and they got a large order from me that day.... I also have a dennys driveshaft in my car.... Works like a champ
chrs1313
05-18-2012, 11:09 AM
same one i got... 1.28 60fts and still going strong...although I am a weak a4...
sorry to hear zeke I was rooting for you on this one...kind of had a feeling they were going to tell you to pound sand...:bs:
Hopefully the fix isnt too bad...
litle88
05-18-2012, 11:39 AM
This is what kills me!
It's not the vendors fault but why would Spohn advertise like this?
http://www.ws6project.com/user_stor/catalog/driveshafts/
http://www.lmperformance.com/78229/1.html
Just an example
rpmauto
05-18-2012, 12:02 PM
That is bullshit, you cant tell me that launching at the track with a 6k clutch dump is less stress then strapped on the dyno. I have a pst shaft and it has taken many a launch with my 402 on spray and never had an issue.
LilJayV10
05-18-2012, 02:16 PM
Spohn's service sucks. At least that was my experience. That's why I use UMI stuff now. Hope you get it back together soon. The car should roll out.
litle88
05-18-2012, 02:25 PM
I can't believe they sent me that email worded that way!!
bluestar435
05-18-2012, 04:01 PM
Their comments are total BS. Although it doesn't get you out of the woods. Everything that is bought has to be checked because you can't count on anyone anymore. Not trying to add insult to injury just stating the facts. Chalk it up to lesson learned cause you won't forget anytime soon. Cut your ties with spohn and go with a PST. Sorry man, it sucks I've been there.
litle88
05-18-2012, 04:03 PM
Yes sir believe me it's going back!
LilJayV10
05-18-2012, 11:53 PM
With Spohns line of thinking should we take a set of new Trick Flow or AFR heads apart when we get them to make sure everything is right?
mercccc
05-19-2012, 08:15 AM
Pst helped me out big time 2 years ago when I ran into an issue with their 3.5 inch driveshaft. Great customer service
litle88
05-19-2012, 08:54 AM
Lol recheck the runner length and combustion chamber and also check spring pressures, BUT DON'T put them on the Dyno because it will create stress on the valvetrain lol
What a joke!
Unfortunately lilj it won't get fixed anytime soon bud, I got a kid in college and 3 more I gotta support plus the wifey plus the mortgage on a popo salary=hurry up and wait!:mad:
litle88
05-19-2012, 08:55 AM
I have NEVER had that kinda luck sir! In my life!
Probably what ill be using too is a PST next time.
Jrp1978
05-20-2012, 03:35 AM
__________________
If you ain’t runnin’ wit it, run from it...
Trying to increase my "useful" post count one post at a time http://images.ibsrv.net/ibsrv/res/src:ls1tech.com/get/forums/images/smilies/LS1Tech/gr_nod.gif
That is very true ! lol! noway in hell afr or trickflow would still be selling shit if you had too!
I had a tv once from samsung they didnt warranty and it was a know issue ! Do what i did i started a tread on there facebook page and hounded them and got 100's of hit from people telling there story ! Low an behold a brand ne 50 inch plazma showed up at my door !
Voice it ! :usa: Its america !
Bramlok
05-20-2012, 10:17 PM
Just from reading some of the responses, I won't be buying anything Spohn in the future. Instead of taking care of the customer, companies end up screwing themselves in the long run when word like this gets around.
Good luck with getting the car fixed. Hope it puts up some strong numbers!
02TransAm/Batmobile
05-21-2012, 12:29 AM
At least the driveshaft would make a good "tool" to pound some sense into these NATO protestors.
fc3slsxpwr
09-13-2012, 07:37 PM
I run 91 or 94 Pump gas
