Mike04
05-15-2012, 07:17 PM
****SOLD****
For Sale is my 2011 United Trailers car trailer located in Jacksonville Florida. I purchased it new just over a year ago and have put about 6,000 miles on it. I chose this model specifically due to it having a low (9 ½ inch) interior wheel well. Most cars are able to open the driver’s door via the left side escape door without having to raise the car off of the trailer floor in some fashion as many other trailer models require. Gen 3 Viper has plenty of clearance to open the car door via the escape door when the car is strapped to the trailer.
The trailer is in near perfect shape, it does have an area on the right rear corner that has a few small dent marks in the aluminum.
Asking $7995
Here are the specifics;
• 2011 UNITED TRAILERS UXT-SERIES FLAT TOP ENCLOSED CAR TRAILER
• MODEL: UXT-8.524TA52
• 8.5' WIDE X 24' LONG X 6'6" INTERIOR HEIGHT
• GVWR: 9,990 LB
• EMPTY WEIGHT: 4,380 LB
• INCLUDED OPTION(S):
• 1' EXTENDED TONGUE W/ 3rd MEMBER - 11 GAUGE TUBE, INCLUDES 7K SQUARE TUBE DROP LEG JACK
• JUMP DOOR OVER WHEEL WELL ON ROAD SIDE W/ BAR LOCK - 48" WIDE X 58" HIGH, 9-1/2" OFF OF FLOOR & 7'7" FROM REAR
• 6-LUG 15" ALUMINUM 08 SERIES WHEELS IN PLACE OF STANDARD WHITE STEEL WHEELS
• EPOXY GLUED EXTERIOR PANELS
• 11/32" WHITE VINYL INTERIOR WALL BOARD IN PLACE OF STANDARD 3/8" PLYWOOD
• FINISH LINE PACKAGE -
• - 48" CURB SIDE DOOR W/ RV DOOR LOCK
• - RAMP REAR DOOR W/ SPRING ASSIST & END FLAP
• - BEAVERTAILED FLOOR FOR E-Z LOADING
• - (4) HEAVY DUTY RECESSED D-RINGS, (2) 1' FROM REAR & (2) 18' FROM REAR 40" APART
• - (2) 12 VOLT QUARTZ/HALOGEN LOADING LIGHTS W/ WALL SWITCH
• - BRIGHT ALUMINUM WRAP ON REAR DOOR FRAMING
• - (1) NON-POWERED ROOF VENT
• - WHITE VINYL CEILING LINER
• COLOR: CHARCOAL METALLIC
• STANDARD FEATURES:
• (2) DEXTER 5,200 LB INDEPENDENT TORSION SUSPENSION AXLES
• ELECTRIC BRAKES ON ALL WHEELS
• E-Z® LUBE HUBS
• ST225/75R15D 8-PLY RADIAL TIRES
• NITROFILL TIRES (NITROGEN)
• 7-WAY RV MOLDED PLUG
• 2-5/16" COUPLER
• SAFETY CHAINS
• BREAKAWAY KIT W/ CHARGER
• STEEL UNI-BODY CONSTRUCTION
• 16” ON-CENTER FLOOR CROSS MEMBERS
• 16" ON-CENTER WALL POSTS
• 16" ON-CENTER ROOF BOWS
• UNDERCOATING ON LOWER FRAME
• 3/4" PLYWOOD FLOOR
• (2) 12-VOLT DOME LIGHTS W/ WALL SWITCH
• L.E.D. TAIL & CLEARANCE LIGHTS
• .030 SMOOTH ALUMINUM EXTERIOR
• ONE-PIECE ALUMINUM SEAMLESS ROOF
• LUAN REINFORCEMENT LINING UNDER ENTIRE ROOF SHEET
• ROUNDED AERODYNAMIC FRONT CAP
• BRIGHT FRONT CORNERS
• ALUMINUM FENDER FLARES
• ALUMINUM TREAD PLATE STONE GUARD
• WEATHER GUARD COATING ON FASTENERS
• 7 YEAR LIMITED MANUFACTURER’S WARRANTY
• 25 YEAR LIMITED FLOOR WARRANTY
MODIFICATIONS TO TRAILER:
• HORIZONTAL STYLE E-TRACK ON INTERIOR WALLS AND FLOOR WITH RE-ENFORCED FRAMING IN
FLOORING TO SUPPORT E-TRACK MOUNTING
• CARPET ON INTERIOR WALLS
• 2 CRANK DOWN STABILIZER JACKS ATTACHED TO REAR OF TRAILER
ADDITIONAL ITEMS INCLUDED WITH TRAILER
• 9 E-TRACK STRAPS
• OVER THE TIRE AUTOMOTIVE E-TRACK TIE DOWN STRAPS
• PRO SERIES TRUNNION BAR WEIGHT DISTRIBUTION HITCH
• SPARE 8-PLY RADIAL TRAILER TIRE MOUNTED ON SILVER MODULAR WHEEL
http://i50.tinypic.com/2zgc3kn.jpg
http://i47.tinypic.com/2d7a82a.jpg
http://i45.tinypic.com/azfehy.jpg
http://i45.tinypic.com/nzn15j.jpg
http://i46.tinypic.com/2zgwvx3.jpg
http://i46.tinypic.com/21j2frk.jpg
http://i48.tinypic.com/2hr1y4w.jpg
http://i46.tinypic.com/wbz0av.jpg
http://i48.tinypic.com/23jsthj.jpg
http://i45.tinypic.com/35ddj7r.jpg
http://i46.tinypic.com/18i1wx.jpg
http://i50.tinypic.com/29fvz2x.jpg
http://i45.tinypic.com/mcd9ux.jpg
http://i50.tinypic.com/28qq2du.jpg
Asking $7995
• GVWR: 9,990 LB
• E-Z® LUBE HUBS
• 2-5/16" COUPLER
• SAFETY CHAINS
• 9 E-TRACK STRAPS
