Car intake on a truck with a truck water pump
Old 05-15-2012, 08:48 PM
94krawler's Avatar
Default Car intake on a truck with a truck water pump
I have always seen you must change the water pump to use a car intake. Tonight I'm setting my car intake on and put the truck t-body on and the water pump fit's. I needed to remove the tab for the cruise control off the t-body but it does fit and work perfect but it is a close fit.
I plan on rotating the water neck some but even if you didnt a small dimple would give you more clearance if desired. The truck motor is a 99 and the car intake is a early LS1 F-body intake.
Attached Thumbnails Car intake on a truck with a truck water pump-car-intake-truck-water-pump-front.jpg   Car intake on a truck with a truck water pump-car-intake-truck-water-pump-top.jpg
Old 05-15-2012, 09:00 PM
Rocketrod's Avatar
FYI - The 2008 TBSS water pump will work with a car intake also. Click the link in my signature and look for the pic in post #7.
Old 05-15-2012, 09:10 PM
94krawler's Avatar
Thats a clean ride
Old 05-15-2012, 09:45 PM
02ssclone's Avatar
U can run the ls1 style but u got to switch the pullet to the truck one, or buy pump spacers. If going into car the alternator might hit the hood.
Old 05-15-2012, 09:51 PM
Rocketrod's Avatar
Originally Posted by 94krawler
Thats a clean ride
thanks...
Old 05-15-2012, 10:02 PM
94krawler's Avatar
Theres a smaller 105 amp Alt. that bolts right on that gives about a inch from what I've found so far. I havent grabbed one yet though to compare.
Old 05-15-2012, 10:10 PM
02ssclone's Avatar
there is a relocate bracket for just the alt.
http://www.ebay.com/itm/Truck-SUV-Ca...item35bbec9546
Old 05-15-2012, 10:23 PM
94krawler's Avatar
Thats a slick setup but I dont think it will fit in my application. My front end is narrowed and theres 2 coilover towers under the hood straddling the engine with a brace over top.
http://inlinethumb01.webshots.com/26...600x600Q85.jpg
Old 05-15-2012, 10:37 PM
BOXCHEV's Avatar
Old 05-15-2012, 10:53 PM
94krawler's Avatar
Why? Mine fit's, everything I ever found said it DID NOT fit, hence why I posted a pic of it clearing. I'll be running mine this way.
Quick Reply: Car intake on a truck with a truck water pump
