Gears & Axles - arc welding rear?
View Full Version : arc welding rear?
therabidweasel
05-16-2012, 05:34 AM
Hey guys, been curious about this for awhile. Has anyone used an arc welder for relos or that nifty axle tube brace or do you have to MIG them? I only have arc and have been avoiding welding because it would seem to be too hot.
Ethan[ws6]
05-16-2012, 08:05 AM
Welding is welding. Put them on however you'd like.
reinhardt02
05-16-2012, 05:59 PM
further agree welding is welding. Just make sure you observe good practices. Good ground. Disconnect battery. Clean both pieces of steel to shiny bare metal.
Bob@BruteSpeed
05-17-2012, 08:59 AM
If you use a stick welder I would use 6011 rod, which gives good penetration and is an all position rod. Bob
therabidweasel
05-18-2012, 03:10 AM
Thanks guys and for the suggestion on the 6011, been meaning to pick some up. Not sure if I have the stones/skills as I have, ehem, taught myself how to weld. . .but I had previously been under the impression the stick welding the rear is not a good idea. Thanks.
GtoSpd
05-25-2012, 09:47 PM
Stick welding is a hot weld. Just don't over do it. I'm no pro welder, but I've used an arc welder for years and found that it will definitely burn a hole right through less than 1/4 inch steel, and can also weaken some steel if you weld too long in one spot. I would think that the axle tubes are plenty thick to use an ARC welder on, but if you're leaving any bearings in near your weld points, I would either take them out or use a lighter welder.
Bob@BruteSpeed
05-26-2012, 07:15 AM
6011 1/16, 3/32 and 1/8 welding rods are available, and work better for thinner metal. 1/8 is probably what I would use on a rear-end, and remember to keep the rod dry. We use to use an old refrigerator with a light bulb mounted in it to keep the rod warm and dry. Bob
