General Maintenance & Repairs - Easiest way to get steering wheel controls?
marksboy7
05-16-2012, 11:16 AM
What is the easiest way to obtain having a steering wheel with radio controls in a car that doesn't have them? Swap just the steering wheels, swap the whole column? If I swap the whole column then I'll have to swap the ignition cylinder over unless I have the keys to the new column correct?
LS1121
05-16-2012, 11:48 PM
If you can get a column with the key it is easy to replace. Do some reading here because you will need to install the wires to the radio and then there is the Vats issue. Not too hard to do, I did it.
wssix99
05-17-2012, 06:43 AM
You need a new steering wheel and clockspring. You may find that getting a used column is the least expensive way to get these parts.
For the install, I'd just replace the wheel and clockspring rather than pulling the entire column.
marksboy7
05-17-2012, 08:00 AM
Thanks wssix99. I've read over your how-to on removing and replacing stuff dealing with the column/steering wheel. I already have a steering wheel with the radio controls, I guess I just need to find a clock spring with the radio wire on it.
marksboy7
05-17-2012, 08:46 AM
Do you happen to know a part number for the clockspring? Is the same clockspring used on any other vehicle?
wssix99
05-18-2012, 10:07 AM
Have you searched for threads on this? They may be old, but there have been threads describing everything step-by-step.
LS1121
05-18-2012, 11:53 AM
Good Luck on the clockspring,I had trouble finding one that is why i bought the whole column off Ebay. I think I paid $50 on a bid plus shipping..steering wheel, air bag everything I got a Great Deal.There are Many threads describing the process.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
