Oil pump question
Oil pump question
I've read on this forum that 98 T/A oil pumps were not built as well as
later models. My bird has 137k on it, and oil pressure cold is around 40-45psi, hot drops to around 20psi. My question is should I replace the oil pump, and can it be change without pulling engine. Thanks for any help!
Kenneth
Kenneth
Could be your bearings are going bad. But to answer you Q, Yes you can change with motor in car.
http://www.ls1howto.com
