Generation IV Internal Engine - Cam swap question L92/Remove VVT
View Full Version : Cam swap question L92/Remove VVT
Sting67ray
05-16-2012, 01:27 PM
What do i need to change to put a non-vvt cam in a L92 besides the cover and cam sensor?
Jimbo1367
05-16-2012, 01:50 PM
From TSP (link & bottom) ]
"VVT Delete Kit
item# 25-VVTDelete
-Share on emailShare on printMore Sharing ServicesShare
-VVT Delete Kit
-All the parts you need to remove the Variable Valve Timing System from your VVT vehicle.
-VVT Delete Kit, Includes: LS3 Front Timing Cover with Cam Position Sensor, 3-Bolt Cam Gear (4X), and ARP Camshaft Bolts. "
http://www.texas-speed.com/p-724-vvt-delete-kit.aspx
litle88
05-16-2012, 03:09 PM
You can also buy a lot of those items used except the Ls2 lifters and lifter trays which I would get new any how. Just my .2
Sting67ray
05-16-2012, 03:18 PM
Jimbo,
That was perfect link thanks.
What else should you replace besides the springs,and cam. I am looking for say 450 Rear wheel horsepower.
Thanks,
Tom M
Hy82e
Are most guys using the original oil pump? Any pressure problems, or problems when using with a fbody or cts-v pan?
Jimbo1367
05-16-2012, 09:12 PM
Some. Chris @ MAST says the AC Delco PF-48 filter has the pressure relief valve buit in. FWIW
Any pressure problems, or problems when using with a fbody or cts-v pan? No problems. Pan depends on swap. Camaro4 pan here.Jimbo,
TVMWhat else should you replace besides the springs,and cam. I am looking for say 450 Rear wheel horsepower.
Hardened push rods Highly recommended
Sting67ray
05-17-2012, 08:32 AM
Jimbo,
Thanks again :cool::cool::cool:
