Michael55123
05-16-2012, 01:34 PM
I have a TON of stuff I need to get rid of.
8X Intel Atom 230 Thin Clients. They're intel D945GCLF boards. They vary in memory some have 256, some have 512, and a couple have 2GBs. One is missing the memory, but I did test it with a stick and it's working fine. They're all in Micro ATX Cases. 6 out of the 8 also have 4GB of onboard flash on them, and have a version of Linux on them. They have SATA onboard and a hard drive could be put in. Could make great workstations, media pc's etc.. Very small form factor and low power consumption. Looking to get 130-180 depending on memory and flash memory configuration. Take all 8 for 500 bucks.
2X Cedar Systems Nutshell thin clients. They have a RDP client built in, and run windows CE. Very small form factor. 20 Each, 35 for both.
1X ATI Rage XL Pci Video Card - 5 Bucks?
1X WinTV HVR-1600 ATSC/NTSC Tuner PCI http://www.amazon.com/NEW-Hauppauge-.../dp/B0065NV3MA -- 70$
1X Four Port 10/100 PCiX Nic, Intel Chipset. Works in Linux, FreeBSD, and Windows. - 40$
1X Dual Gigabit Intel Pro/1000MT PCiX Card - 40$
1X Broadcom PCIe Gigabit Nic - 15$
1X Sound Blaster X-Fi Extreme SB0460 - 50$
1X Low Profile DVI Video CArd - 5$
1X Addonics 5 Port Sata Port Multiplier (PMP) PM-AD5SAPM http://addonics.com/products/ad5sapm.php - 50$
1X 2 Port Sta Card - Works with Port Multiplier - 10$
1X PciE Gigabit Nic - 10$
MEMORY
1x 512 MB Laptop DDR 333 PC2700S
4x 2GB PC25300F - Notice the F this is Fully Buffered ECC - 25$/ea
2X 256 MB 133Mhz SDRAM ECC 5$ 7 for Both
1X 256 133 Mhz SDRAM - 5$
1x 256MB 133Mhz Registered SDRAM - 5$
1X 128MB 100Mhz SDRAM - 5$
1X 512 DDR2 PC2-3200U - 10$
1X 256MB DDR2 PC2-4200U - 7$
1X 512MB DDR2 PC2-4200U - 10$
1X 2GB DDR2 667 Mhz - Kingston KVR667D2N5 - 20$
1x 512MB DDR2 4200F - Fully Buffered - 8$
2X 512MB DDR PC2100R - Registered - 7 ea - 12 for both.
1 500GB Sata drvie. Seagate ST3500320NS - 40$
1 Server. SuperMicro chassis. - 400$ - PERFECT for VMWare ESX testing, etc...
6X HotSwap SAS Bays.
1X Hotswap SATA Bay
Loaded with 3X 73GB 15.5K Seagate Drives - ST373455SS
Onboard SAS RAID
Intel S5000VSA Board
2X Xeon E5420 Quad Core CPU's
Can do vmware ESX, etc...
Dual Power Supply
2 Port SATA Card for Hotswap Bay
DVD Burner
8GB ECC DDR2 - have 8 more available above as well. Has room for it.
Canon NP6016 Commercial Copier - Unknown condition - 50$ - Thing is big, and comes on an aluminum cart.
IP KVM - PS2/USB - 80$
For 1100$ Bucks you can have it ALL. Every single thing listed above. I'm open to interesting trades, etc... If you have any questions just shoot me an e-mail. Open to offers, need to get this stuff moved. Please E-Mail not PM at mike@e-junky.net.
Thanks,
Mike
MEMORY
1X Hotswap SATA Bay
Onboard SAS RAID
Dual Power Supply
DVD Burner
Thanks,
Mike
