BlackedOut LS1
05-16-2012, 02:06 PM
I'm about to pick up a ported fast 92, with a ported Nick Williams TB and fuel rails. I understand I have to upgrade the injectors, what's the optimum size I need and what kind of money do I need to budget for the injectors?
ZL1Killa
05-17-2012, 09:30 PM
whats your basis of you saying that you need to upgrade injectors in order to do an intake and throttle body swap? What else do you have done to the car?
JUST those mods alone will not require you to upgrade your injectors.
but if you are looking for injectors...I recommend 42# injectors or even slightly larger regardless, this way it gives you plenty of breathing room, HOWEVER, that being said. I need to know what all mods you have done to your car and what your car is to give a REAL suggestion on injectors.
