Cadillac CTS-V - Am I blind, dumb, or stupid.... Setting clock
Turbo Pig
05-16-2012, 02:20 PM
Owners manual says press the Sel knob and choose the set time. I don't see it anywhere. Ugh.
Help.
CTSV_510
05-16-2012, 02:44 PM
You press the setup button in the very bottom left corner you can see in this picture.
http://cadillacfaq.com/faq/answers/img/diag/navbrb.jpg
Then you use the buttons on the right with the on-screen descriptions to set the clock.
garrettg
05-16-2012, 04:14 PM
Don't use the nav time as it won't stick(thanks gm), use it as a guideline but manually put in the time for saving.
Turbo Pig
05-16-2012, 05:08 PM
I don't have a nab disc apparently. How do I correct that.
This is the screen I get when hitting the knob. No clock adj
http://i15.photobucket.com/albums/a375/silver2000svt/32cd9faa.jpg
kl2onik
05-16-2012, 05:12 PM
lol I had to automatic gps it like 3-4 times till it finally stayed at what it should be
Turbo Pig
05-16-2012, 05:17 PM
Just got it yay.
Now how the fuck do I get the DPS changes I make to save in the audio?
Turbo Pig
05-16-2012, 05:18 PM
And where can I get a nav DVD.
ITSAV
05-16-2012, 05:32 PM
Nav DVD's can usually be found on ebay, just need to do a search to find out what one you need, and you should be able to get it off ebay
aurora40
05-16-2012, 06:24 PM
When you set the time from GPS, you just have to be sure to click "Ok" from the side buttons. Otherwise it won't stick. That is true if you adjust it manually, except it seems more obvious doing it manually.
To get to the time setting, you can also push the "Menu" button in the lower left.
kl2onik
05-16-2012, 07:03 PM
pm serik21 on here he has them...new updated version
furbe
05-17-2012, 03:52 AM
This^
FBDYLVR
05-17-2012, 11:42 AM
Just got it yay.
You need to enable Personalization features and make sure you're Driver 1 or Driver 2. Then all the radio settings should stick.
raven154
05-19-2012, 11:15 AM
Radio settings only stick for the preselected station as well. You will have to set all your presets to the audio levels you want and save each on individually.
Turbo Pig
05-19-2012, 12:59 PM
How do I do that?
