Pin striping removal
My 2000 z28 came with thin gray in striping down the entire length of the car. Time and the sun have made it start cracking and fading. Ive waxed over zillions of times. I want to remove it but not sure the best way to do it. And will the paint be discolored vs the regular paint. Any tips will help.
Plastic razor blades FTW!
http://www.autogeek.net/scraperite-p...or-blades.html
Put a piece of masking tape on both sides. This lifts the razor up just enough not to scratch the paint. Leave just enough of the razor showing to peel the pin striping off. You still have to be careful, but this is the safest way. The paint shouldn't be faded. If you really had to, you could use some polish on a microfiber if you don't have a machine and other detailing stuff.
my paint is faded to hell. i said fugg it and used a razor blade. (not rubber) worked ok just made different stripes.. lol. the razor took some clearcoat with it so long story short i still have pinstripes
EDIT: goo b gone or alcohol did nothing to remove them razor was last resort. but this was before i found ls1techs handy search bar
