Cadillac CTS-V - My V is swerving/floating under hard acceleration
johnny6
05-16-2012, 08:11 PM
I'll make this as short as possible. Today i ran over a flat piece of metal which probably got kicked up with my front tire and then got ran over with my rear right tire and blowing it out :mad: Both rear tires have less than 2k miles on them. In the rear i'm running Sumitomo HTR Z II 275/40 but now i have a fairly new 245/40 bridgestone that i had stored and now it's replacing the busted Sumitomo. Well under hard acceleration the car feels like it floats from side to side and i have to try hard to keep it straight, is this common with a different sized tire or do i have have something else going on? I ordered a new 275 which will hopefully be in this week. Oh yeah, here's some pics of the piece of metal and tire
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/s720x720/535284_3615118650286_1043424010_3317102_57488739_n .jpg
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc7/s720x720/389640_3615086209475_1043424010_3317093_1071464640 _n.jpg
wcryan
05-16-2012, 08:37 PM
did it go all the way through?
johnny6
05-16-2012, 08:45 PM
Yep, it was barely sticking out of the tire and it was a pain in the ass to pull it out.
NeverSatisfied02
05-16-2012, 09:00 PM
I wouldn't think the tire would cause that since its the same overall diameter. I notice my car feels kinda wishy washy in the ass end at times when accelerating but more so when cornering. I posted a thread about this awhile back and no one had an exact answer as to what causes it. I'd bet it has something to do with the cradle bushings in the rear and possibly tailing arms or whatever else is back there that's supposed to keep the car planted but could be gettin worn out.
heavymetals
05-16-2012, 09:40 PM
Did you have it aligned?
Improper toe in (not enough) of the rear can cause it to "walk" or drift under acceleration.
odthetruth
05-16-2012, 11:12 PM
Its not the same overall diameter. A 275 40 18 would put a 26.7 inch diameter... a 245 40 18 would put a 25.7 inch diameter. An inch shorter, which is significant enough to affect handling. If you have a 245 45 18, you'd be where you needed to be in terms of tire diameter.
So yeah, I think an inch shorter tire then the others can affect the handling.
NeverSatisfied02
05-16-2012, 11:34 PM
Ahhh... missed that. Thought it was a stock 245 he was running. I didn't see that it was a 245/40.
odthetruth
05-17-2012, 12:07 AM
LOL Yeah. Stockers would be a perfect match at 245 45 18s.
johnny6
05-17-2012, 07:56 AM
Not yet, as soon as the matching tire comes in i will definitely get it aligned, thanks!
That makes a lot of sense, this weekend i'm going to look at the rear suspension and make sure nothing is messed up just in case.
NOLAG05
05-17-2012, 08:08 AM
dayum the tire how did you get a pic of my wife as your avatar...lol
EdmundGTP
05-17-2012, 12:31 PM
A full inch shorter in diameter and you didn't notice? HELL F'N YEAH that will cause problems. Aside from that, if you have the smaller tire installed as a temporary fix that you aren't 100% sure of, functionality wise, WHY WHY WHY are you accelerating hard? Personally I wouldn't drive the car at all with tires that mis-matched. JMO
Derek98z
05-17-2012, 12:44 PM
Yeah, too much driving with odd heigth tires can burn up your rear.
johnny6
05-17-2012, 03:33 PM
According to shipping the tire will be here tomorrow, i only got on it once (habit) and when the car shifted i haven't done it since. The tire itself is practically brand new with no issues.
Skidmarcx
05-18-2012, 04:47 PM
The difference in tire diameter shouldn't affect driving too much... If it did the ABS light would come on. If it was a side to side mismatch I'd be more concerned. If you're alignment is good the instability is most likely from the squishy bushings or perhaps worn bushings
odthetruth
05-18-2012, 06:51 PM
... How wouldn't 1 shorter tire on 1 side affect driving? I would agree if all 4 were an inch shorter, but 1 shorter then the others would definitely affect handling and driving.
Skidmarcx
05-18-2012, 07:59 PM
Well for starters I need to learn how to read because I didn't see the part about the odd tire being put on in place of the rear tire. I thought that it was a difference between both front and rears tires...
