Pontiac Firebird 1967-2002 - Will 2006 rear Gto wheels fit a 2001 T/a?
SPEED///
05-17-2012, 07:20 AM
I'm thinking of buying rear 06 Gto wheels to put drag radials on for the trans am. Will they fit? They are 18' wheels
Thanks!
You need to dremel the center. Once that is done, they bolt right on.
great421
05-18-2012, 02:11 PM
Clarification: The bolt pattern is off by 0.65 mm (120mm vs. 120.65mm).
So, what "Rob" says (given the fact that he has both a Goat and a Firechicken) is most likely correct.
SPEED///
05-18-2012, 07:53 PM
Thanks guys! I was just thinking of buying rears for the drag radials. But I guess I'll just hold off.
Zombiesoldier
05-20-2012, 04:29 PM
How do they look they? I'm curious if the look good on a bird.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
