Weld prostar question
Old 05-17-2012, 09:56 AM
blknSS's Avatar
Default Weld prostar question
Looking at a set of prostars.....will they fit?
Fronts are 15x4" with a 1.75" backspace with 26x7.5x15 Mickey Thompson front runners
Rears are 15x8" with a 4.5" backspace with 295x50x15 Goodyear Eagle GTII's
They will be going on a 4th gen ss camaro....thanks in advance
Old 05-17-2012, 11:17 AM
blknSS's Avatar
Stock suspension, with rear lower control arms and an adj. Panhard bar. I have read i might need to grind down the caliper on the rears alittle....and other info you guys can help with? Please.....
Old 05-17-2012, 01:51 PM
blknSS's Avatar
Any help would be awesome here......
Old 05-17-2012, 02:04 PM
chrysler kid's Avatar
5.5 is a typical back space for 15x8 wheels. You should search to see if the front will fit, you will be able to see the typical spacing for fbodies
Old 05-18-2012, 10:36 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
rears aren't going to work for sure
Most run a 15x3.5 with 1.75" backspacing or a 15x4 with 2.25" backspacing on the front
Quick Reply: Weld prostar question
