New LS1 Owners - Newbie Tech - ls6 intake
View Full Version : ls6 intake
02 reaper z28
05-17-2012, 11:18 AM
does anybody know what a stock ls6 inlet size is?
i though it was 80mm but im trying to make sure.
777
05-17-2012, 03:02 PM
78 mm
02 reaper z28
05-17-2012, 10:23 PM
i thought that was the ls1 intake with the egr?
bestlude
05-17-2012, 10:25 PM
both ls1 & ls6 intakes are 78mm ... only difference is the ls6 style intake has no egr ports and most importantly Flows much better.
02 reaper z28
05-18-2012, 01:32 AM
oh ok, thanks for clearing that out.
perf0rmance
05-19-2012, 11:05 PM
Any power gain to be had by switching to a slightly larger MAF? Like an 85mm MAF?
garygnu
05-20-2012, 10:15 AM
the 78mm intake opening size would be the restriction .most people just get a ported stock TB.you can try to port out the intake opening.
perf0rmance
05-20-2012, 02:23 PM
So that's the reason people upgrade intakes. What about the LS2? Would I have to switch to a DBW setup?
Z28/2002
05-20-2012, 09:37 PM
you can buy an aftermarket 90mm throttle body
bww3588
05-21-2012, 12:04 AM
And not see any gain over the ls6 intake...the ls2 intake in stock form is junk.
MonmouthCtyLS7
05-21-2012, 01:31 PM
You'll Only see a few horsepower up top from a LS2 and it's not a direct swap.
