Paint & Body Work - Stress cracks??
Y87bird00
05-17-2012, 05:24 PM
Hey guys i was wondering if anybody has delt with this kind of cracking and spider webbing before and what the best fix would be... ive been to multiple body shops who just want to replace the cover for over 500 dollars....which ends up being over 1,300 dollars by the time its painted. but i did find a shop that is willing to do everything for 750...providing that i sand most of the old paint off to the best of my abilities (bad idea? i know to use 80 grit till i get the cracks out and work up to 850 wet sanding?) this includes repairing the chip/door dings with a thick paint and sand/buffing (will this look like crap?) as well as buffing the whole car. any input or ideas would be great! thanks
frehwk_ls1
05-17-2012, 08:45 PM
start with 180 grit not 80, just keep sanding until all the cracks are gone, you will go all the way down to bumper material before they are gone, ive seen it happen quite a bit on these bumpers, matter of fact my front bumper was spider cracked before i repainted my car
Y87bird00
05-17-2012, 08:51 PM
So you think I should do this myself? I don't have much experience I just don't want to mess anything up even more! Thanks for the help
ramair 1
05-17-2012, 08:59 PM
You can do it just sand off all the clear and color .get yourself a cheap da sander and a couple sanding blocks and go at it.Like frehwk says start with about 180 to 220 grit so you dont damage the plastic.
Y87bird00
05-17-2012, 09:02 PM
Thanks guys!
BlackScreaminMachine
05-18-2012, 06:49 AM
You have a black car so luckily you do not really need to worry about blending as much as any car that is metallic based. If you do 99% of work and bring the part there you can negotiate for them to basically shoot it.
Y87bird00
05-18-2012, 07:10 AM
Awesome thanks!
98camarols1
05-18-2012, 08:08 AM
I'm painting my car and my rear bumper did the same way even with primer surfacer..i had to strip bumper down twice.now going to use either flex primer or spectra primer.so make sure u tell the shop tht just to be onthe safe side.
Y87bird00
05-18-2012, 01:27 PM
Will do, thanks!
HotWhipT/A
05-18-2012, 02:11 PM
As said already, it should be fixable. The body shops just don't want to do all the work on it. It takes lots of sanding, usually to the plastic and then some. What I would do is take the front bumper off and spray paint stripper made for urethane bumpers to get most of the paint off. Then go at it with the DA sander where you can, then hand sand the rest. That's how I did my bumper. It turned out great.
Y87bird00
05-18-2012, 02:23 PM
Thanks!
02TransAm/Batmobile
05-19-2012, 06:56 PM
Would it be easier to apply a paint stripper?
HotWhipT/A
05-19-2012, 10:48 PM
Already on that!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
