General Maintenance & Repairs - LS2 almost stall at start up
Mike_72
05-17-2012, 07:42 PM
I have a drop out LS2 from an 2005 GTO in my RX7 and I can't figure out why it almost stalls when I start it, then seems to recover fine with no input from me. Only code I am throwing is P0315 (crankshaft variation not learned) but from what I have read that shouldn't have any effect on the drivability of the car. after it recovers it seems to run perfectly so I can't figure out why it is behaving this way on startup. engine is bone stock with long tubes and an aluminum LS7 flywheel and clutch.
Attached is a link to a video, (I know its upside down and have no idea why image shack flipped it.)
http://img221.imageshack.us/img221/3628/video13373008430.mp4
LS6427
05-17-2012, 08:17 PM
Slow reacting IAC valve.........maybe......
Mike_72
05-18-2012, 07:41 AM
I thought the DBW motors don't have an IAC valve, I thought they just used the throttle plate.
LS6427
05-18-2012, 11:51 AM
Without an IAC valve.....the PCM can't adjust the idle quickly. You're probably starting the engine and then its struggling to stay alive for that brief period because all thats feeding the engine with air is the small hole in the TB blade, if it even has that hole in it.
The IAC acts very fast to feed the engine air and take it away when throttle is given.
Mike_72
05-21-2012, 09:22 AM
Everything I read seems to confirm that the LS2 uses the throttle plate for idle control and not an IACV
LS6427
05-21-2012, 05:16 PM
What opens and closes the TB plate to control idle if the pedal is not being pushed?
Mike_72
05-22-2012, 07:32 PM
from what I understand the same motor that drives the plate with an input from the DBW pedal is also used to control the plate for idle purposes by taking outputs from various sensors
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
