Fueling & Injection - New to setting up fuel injection
View Full Version : New to setting up fuel injection
thenovaproject
05-17-2012, 10:05 PM
Setting up regulator
Got the red Aeromotive one
What's the chrome long nipple thing used for.
Please help
Thank you in advance
Brian Stankowitz
onefastrx7turbo
05-18-2012, 10:05 AM
sounds like the boost reference nipple. only need it if you are forced inducted. leave it open if not
thenovaproject
05-18-2012, 01:35 PM
Thanks
What does it do if I am running turbos ?
ZL1Killa
05-18-2012, 02:49 PM
it raises the fuel pressure to compensate for the amount of boost you are running. reason for this is your actual injected fuel pressure, if normally 58psi, if you are running 10psi of boost, your actual injector fuel pressure is 48psi; and at that pressure you have to ensure your fuel injectors flow enough to keep up with your setup.
for every pound of boost you increase, the regulator also increases to maintain the equivalent same fuel pressure
