General Maintenance & Repairs - Hi guys please help shifting problem
law87
05-17-2012, 11:11 PM
hi guys, i'm having problem with my T-56, whenever i drive the car, the first time i go into fifth gear, it would always grind and after that it wouldnt do it anymore. Currently i have a willwood clutch master cyclinder, just order a tick MC, will install when it come in, also bleed the clutch. the car currently have exedy OEM clutch. would like some input from different user here and what else i have to do to get rid of this.
also going into reverse is never a problem.
law87
05-18-2012, 08:51 AM
bump no one? cmon guys
law87
05-18-2012, 03:20 PM
bump?
Jr.Samples
05-18-2012, 06:49 PM
Did you try changing the fluid?
law87
05-19-2012, 12:00 AM
what would you reccomend? penzoil platnium?
7camaro7
05-20-2012, 09:55 PM
clutch and/or trans fluid, not engine oil.
ccrook19
05-21-2012, 05:49 PM
Dex 3 ONLY
DONT USE DEX 6!
wrencher
05-21-2012, 10:17 PM
I would bet the blocker ring for 5th is worn.
Or a shift fork pad issue, something likely internal.
Original untouched trans? What year car etc?
trans_am7935
05-22-2012, 04:24 AM
never heard of problems with 5th before, try shifting slower the first time, see if that is the problem, then if it is it could be clutch, or the gears are not engaging properly. sounds like it might be time for a rebuild, cheapest tranny rebuild i have ever done! can beet a warrantied 700ft lb for 1500 bucks!
BOBS99SS
05-22-2012, 05:20 AM
Could be internal, best place for a rebuild is tdp, they gave me a killer price for a stage 2 rebuild,but i think someone told me they were out of buisness or something like that,but i would check them out first
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
