15" Wheel Disc Brake Set-Ups
Old 05-18-2012, 11:27 AM
StraightTimeStirrups's Avatar
Default 15" Wheel Disc Brake Set-Ups
I am working on my 93 TA and it needs new brakes front and rear (rotors, Calipers etc.). Since my car will be a 99% track car, and slow at that, I was wondering if there was a Stock GM Caliper and Rotor set up (That was originally used with a 15 inch wheel)that would work on my front spindles and rear axle that I can replace the stock brake setup with to allow me to run Weld Pro Stars without having to grind the crap out of the calipers?
Old 05-18-2012, 10:31 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Not there isn't
